Is the Body Control Module (BCM) and Front Control Module (FCM) the same on a WK? - JeepForum.com
post #1 of 2 Old 07-08-2019, 11:47 AM Thread Starter
suzieque
2008 WK
I was using my Blue Driver and reading all the error codes. I got a "cannot communicate with body control module" message that i was able to clear, but it eventually came back.
In looking at service information, I cannot find the location of the Body Control Module (BCM). Is the BCM and the Front Control Module (FCM) the same module on a WK?
If not, does anyone know where the BCM is located?
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #2 of 2 Old 12-08-2019, 08:32 AM
HMorgan
2010 WK
BCM Location
Behind the battery mounted to the front of the fuse box
HMorgan is offline
