Blank Buttons - JeepForum.com
post #1 of 6 Old 06-06-2016, 05:20 PM Thread Starter
jameyer3
Blank Buttons
I have an 07 Grand Cherokee and was wondering if the blank buttons in the console can be replaced for usable buttons, like for a light bar. My friend did this in his FJ.
jameyer3 is offline
post #2 of 6 Old 06-06-2016, 05:57 PM
bensylrm
2005 WK
I saw somewhere where someone pulled out those bars and was able to break off the ends of the button inside to make them movable. They then put push buttons glued in behind it and made workable switches out of the blank spots. If I'm not mistaken they even cut out and etched the plastic to make the light shine through to show the switch being on or off. I'll look around for a bit and see if I can find that thread.
Sent from my WK JGC phone...
05 WK 4.7 OME HD F150 MLL's, BFG MT 255/75-17. Lots of stickers, lights EVERYWHERE!
bensylrm is offline
post #3 of 6 Old 06-06-2016, 06:00 PM
bensylrm
2005 WK
That was a quick search.... But the pictures are inop.
https://www.jeepforum.com/forum/f67/h...utton-1077524/
bensylrm is offline
post #4 of 6 Old 06-07-2016, 10:10 AM
wraycoli
2008 WK
I took a stab at this last weekend - Took out the dremel w/ cut off disc and started hacking away.
Bought some electronics push buttons with the intention of fitting a protoboard back there and mounting it to a steel bracket sized to fit the screw spacing of the original plastic cover plate.
http://www.amazon.com/Tact-Tactile-P...ilpage_o01_s00
After making the initial cuts to remove the "buttons" piece from the cover, I realized that making the individual button cuts on the plastic wasn't going to be clean enough to maintain a stock look (cuts were gumming up and cut width was wider than desired), and the extra effort wasn't worth it IMO.
Settled on retro fitting a steel plate in the switch cover area and using flat tabbed SPST toggles from RS.
08WK 4.7 QTII Rocky Mtn| Mod OME HD w/ Bilstein 4600/5100 | GY Wrangler AT Adventure 265/70/17
wraycoli is offline
post #5 of 6 Old 06-07-2016, 07:52 PM
bensylrm
2005 WK
What did you do with the switches that were already there? Or did you not have any switches in there?
bensylrm is offline
post #6 of 6 Old 06-07-2016, 08:48 PM
wraycoli
2008 WK
No switches, just the placeholder cover with faux switches.
wraycoli is offline
button , console , light , upgrade , wiring
