Bedliner. pros and cons? - JeepForum.com
post #1 of 15 Old 02-07-2016, 01:20 PM Thread Starter
Tobeornottobe
2005 WK
I will be doing some stuff on jeep soon , thinking about using bed liner on door step plates . . Exterior moldings and as a under carriage coating after the por 15 treatment , any one have comments ... Does it last will it fade .?? How long will it hold ?? Flake chip peel???
Same for plasti dip pro cons?
Tobeornottobe is offline
post #2 of 15 Old 02-07-2016, 01:39 PM
sheepdog918
sheepdog918's Avatar
2007 WK
Bed liner is MUCH MUCH more durable than plasti dip. It will also fade a lot slower, and protect better as well.
On the other hand you can peel plasti dip off, so if you don't like it you can just remove it. Good luck with peeling bed liner off lol
There are the wolves, there are the sheep, but then, there are the Sheepdog's
sheepdog918 is offline
post #3 of 15 Old 02-07-2016, 05:17 PM
btburn
2007 WK
I did the rims, fenders and bumpers with the Duplicolor Bed Armor on my JK and it lasted great for over 6 years until I sold it and it looked great and barely faded easy to touch up scrapes too by just dabbing more into the scrapes. Just make sure you clean and scrub really good before applying. It doesn't compare to powder coating on rims but it's cheap and you can do it in a weekend. Clean and scrub or it will peel under pressure washing.
btburn is offline
post #4 of 15 Old 02-07-2016, 09:40 PM
DavidGascon
I love the looking bed liner on my exterior trim pieces. I did my mirrors, and smaller trim pieces. The only con is that if you have a soft cloth to clean your jeep with, the fabrics will get caught on the Bedliner. Aside from this, Bedliner beats plasti dip. I did my wheels in plastidip a year ago, and it is starting to fade already.
Cheers!
DavidGascon is offline
post #5 of 15 Old 02-08-2016, 08:30 PM
jediknight
2008 WK
I dont understand... I thought bed liner is for pickups no?
2008 WK CRD Blue, QD II, Startech SD6 mod.
jediknight is offline
post #6 of 15 Old 02-08-2016, 10:57 PM
sheepdog918
2007 WK
Yes primarily. But, you can buy spray cans of it and use it for virtually anything. Really common on plastic trim that fades from sunlight, or to cover up bare metal that rust can get at.
post #7 of 15 Old 02-09-2016, 02:47 AM
JakeWK
JakeWK's Avatar
2005 WK
*ALL plastic trim and ALL bare metal
05 WK HEMI
USN Jeep Club
CentralCaL 4X4
Colorado 4X4
JakeWK is offline
post #8 of 15 Old 02-17-2016, 09:18 AM Thread Starter
Tobeornottobe
2005 WK
So I'm looking for the dupi liine of bed liner spray , can't seem to find it ... . Also hat are thoughts on using the por 15 on drive shaft ? Anything else I should not cover with it ?
post #9 of 15 Old 02-17-2016, 09:20 AM Thread Starter
Tobeornottobe
2005 WK
Before
post #10 of 15 Old 02-17-2016, 10:09 AM
DK2005WK
2005 WK
My front winch bumper was sprayed with Dupli-color truck bed liner. I like the rugged feel and is way cheaper than powder coating. It's only been on a month, so not sure how long it will last until it needs a touch-up. Will be spraying my rear bumper/tire carrier with the same to match once its done.
05 WK 5.7 Hemi - Modified 6" SL, Bilstien 5100's all around, JBA 6" Rear Coils, 315/70/17 BFG AT's on 17x9 Procomp Rockcrawler Rims, RRO Super Rock Sliders.
DK2005WK is offline
post #11 of 15 Old 02-17-2016, 11:59 AM Thread Starter
Tobeornottobe
2005 WK
Nice looking jeep !!!! Is it fairly smooth or pebbled ?
post #12 of 15 Old 02-19-2016, 08:47 PM
djleatherb15
2005 WK
What kind of bumper is that?
djleatherb15 is offline
post #13 of 15 Old 02-20-2016, 01:29 AM
MyJeepStory
MyJeepStory's Avatar
2005 WK
I really recommend going with Chassis Saver (almost identical to POR-15). It costs maybe $40 to do yourself and you can end up with permanent and amazing results. I did mine over a year ago and it still looks amazing. Before I used Chassis Saver, I used Rustoleum's Rubberized paint and it didn't last longer then the tank of gas I had at the time...
I also made a video on my year after review of Chassis Saver! Click below!
Chassis Saver: One Year Later
See the story-
MyJeepStory is offline
post #14 of 15 Old 02-20-2016, 01:31 AM
MyJeepStory
2005 WK
One other thing that I want to add is that not many bed liner or rubberized coatings are UV resistant at all, so fading is inevitable. Check out a product like Monstaliner which is 100% UV protected and guaranteed to last.
See the story-
post #15 of 15 Old 02-22-2016, 01:04 AM
derpboss
crawl offroad. about $1200. i like the looks of that one better, but i think i'll end up with the tactical armor group one for about half the price.
derpboss is offline
