Battery not charging - detailed troubleshooting - Page 2 - JeepForum.com
post #16 of 16 Old 02-11-2019, 12:04 PM
97grand8165
97grand8165's Avatar
Had the same thing happen in my 95 grand. After checking the wiring , battery , fuse-able link and battery all tested good. It was the voltage regulator in the ECM/PCM . Everything else worked so I didn't want to buy a new comp. Ended up getting a voltage regulator from a 70's mopar stand alone unit works perfect now . Put in an inline fuse with a switch to stop the battery drain. It was a 30 dollar fix well worth it. I have 4 jeeps all zj 95, 96, 97, 98.
97grand8165 is offline
alternator , battery , charging , dead , short
1995 ZJ not charging battery bcridez3 ZJ Grand Cherokee Forum 8 02-11-2019 12:18 PM
Battery Dying! Help troubleshooting... JeepNuBee ZJ Grand Cherokee Forum 5 10-20-2008 12:08 AM
Idle RPM/CTS/PCM/battery vs charging & starting problems Aceladriver ZJ Grand Cherokee Forum 2 01-11-2008 01:41 PM
Detailed pic request... BlackPearl96 ZJ Grand Cherokee Forum 0 03-18-2007 08:50 PM
Jeep Will not start after charging battery!!! coolest_Stan ZJ Grand Cherokee Forum 13 10-19-2005 04:02 PM
