Bad A/C clutch coil / how far should I go? - JeepForum.com
post #1 of 10 Old 06-05-2020, 09:32 PM Thread Starter
dmilner57
Hi all, new member here.
I have a 2008 5.7 and the a/c clutch coil is open. It looks easy enough to pull the compressor out bringing it up the side. It also looks almost impossible to just pull the clutch without taking a whole lot of stuff off the front. Iím opting to pull the compressor unless someone convinces me otherwise.
So how far do I go with parts? It has 153k on it and the air was working fine last year.
My gut says shotgun the thing, new compressor, dryer, etc.
My bank account says pull it, put a new coil in it, and run it until it quits again.
So how far do I go with this??? How much life would the average compressor with 153k have left in it?
dmilner57 is offline
post #2 of 10 Old 06-05-2020, 10:48 PM
thearborbarber
2006 WK
12 years old and 153k miles, I'd get a new compressor. Then you only have to recharge the system once. This style compressor start to leak around the shaft seal behind the clutch. It's a crap shoot if it fails or not.
2006 GC Laredo 3.7 mostly stock
thearborbarber is offline
post #3 of 10 Old 06-06-2020, 06:21 AM
groverson
groverson's Avatar
1936 CJ3A
Would you invest in a OEM Mopar compressor? Expensive! My 08 5.7 AC is still going strong at 115,000 miles.
Sent from my iPhone using Tapatalk Pro
groverson is offline
post #4 of 10 Old 06-06-2020, 06:38 AM Thread Starter
dmilner57
I never use OEM unless I have no other choice.
post #5 of 10 Old 06-06-2020, 06:40 AM Thread Starter
dmilner57
Do you know if the remanufactured hold up?
post #6 of 10 Old 06-06-2020, 09:50 AM
groverson
groverson's Avatar
1936 CJ3A
Not sure but I donít think my 08 Commander will last another 12 years so Iíll probably go with remanufactured.
post #7 of 10 Old 06-06-2020, 03:23 PM
johnniebravo
2008 WK
The cost of the replacement clutch coil is 1/2 the cost of a reman Denso compressor. I'd change it. I'd make sure to use the proper compressor oil (double end capped PAG 46) and a new drier.
So far I have had great luck with reman Valeo alternators and usually they are junk (remans).
In my head I have some false hope for remanned components, at least those that fit the CRD motor.
2008 CRD GC
johnniebravo is offline
post #8 of 10 Old 06-06-2020, 03:41 PM Thread Starter
dmilner57
Well I decided to shotgun it with new parts for the lifetime warranty. $450 for a new compressor, dryer, and expansion valve.
post #9 of 10 Old 06-06-2020, 08:07 PM
Alex_
word of advice, you cannot only change the compressor, you need to change the dryer receiver/Accumulator , A/C condenser and maybe the expansion valve; changing just the compressor and leaving the condenser and dryer can cause damage to the new compressor because most likely there are metal particles floating in there from usage.
Alex_ is offline
post #10 of 10 Old 06-06-2020, 09:32 PM
terrasmak
2007 WK
After swapping the expansion valve in my G35, I donít even want to know how much fun the jeep will be.
I wouldnít swap the valve unless the compressor failed
"Racing makes Heroin addiction look like a vague wish for something salty." -- Peter Egan
terrasmak is offline
