Any way to trick the TPMS? - JeepForum.com
post #1 of 7 Old 02-20-2020, 05:32 PM Thread Starter
AndyWood
2007 WK
The winter tires are perfectly inflated, but sensors are reading from 0 - 35 for the 4 tires. Anyway to dismiss this, or trick it into thinking the sensors are reading good values? (pull a fuse, etc?)
thanks!
AndyWood is offline
post #2 of 7 Old 02-21-2020, 01:40 PM
90grandoneer
90grandoneer's Avatar
2006 WK
I don't know of any way to "trick" the TPMS, but they're not rocket science to troubleshoot and fix. The three main components are the trigger units (all wheels but the left rear), the sensors in the wheels (all 4 or 5), and the Wireless Control Module located under the dash on the driver's side. All can be easily checked (and serviceablitlity verified) with a good (not cheapo) scanner and a TPMS Service Tool. Any tire shop worth their salt should have these tools and be able to tell you where the problem is located in about 10 minutes.
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, AFE Air Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, DS and HP tuners, Transgo Shift Kit, ARH Long Tube Hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam w/6* advance/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, TEA ported/milled heads w/new valve seats, SRT Reps with 265/45&295/40X20's. Also 05 Hemi LX modded exactly like WK and Comp Cammed 06 300CSRT8.
90grandoneer is offline
post #3 of 7 Old 02-21-2020, 09:57 PM
CommanderRandy
2007 XK Commander
Can you explain the "no trigger unit" on the left rear? My Commander thinks there's no left rear wheel back there and I'm getting sick of that stupid light
Previous Jeeps: 89 YJ, 92 YJ, 99 XJ, 98 XJ
Current Jeep: 07 XK Commander limited w/HEMI
CommanderRandy is offline
post #4 of 7 Old 02-22-2020, 09:13 AM
90grandoneer
2006 WK
From the Factory Service Manual:
"A transponder is located in three of the four wheel wells of the vehicle to provide the WCM/SKREEM with the location of the tire pressure sensors on the vehicle. The transponders are located in the left front, right front and right rear wheel wells. A fourth transponder is not necessary in the remaining wheel well due to the process-of-elimination theory. Once the system knows the location of the first three sensors it assumes the location of the fourth tire pressure sensor is in the left rear tire."
post #5 of 7 Old 02-23-2020, 08:03 AM
NevadaWheeler
2005 WK
Does that mean that it doesn't look at the spare tire? I just had a flat yesterday (front right) and put the spare on. I still have the TPMS light, but I thought that was because the tire, now in the spare location, still was flat.
NevadaWheeler is offline
post #6 of 7 Old 02-23-2020, 11:36 AM
90grandoneer
2006 WK
The first thing I'd do is check to make sure all of your TPMS Sensors, especially the spare, are still working. For each wheel equipped with a sensor, a TPMS Service Tool will, at a minimum, tell you the ID number, radio frequency, battery status, air temp. in the tire, and actual air pressure for that wheel. This should be the first thing you should check and. if the sensors are all good, check to see if the pressures are within the "Placard Pressure Threshold." Many times, folks will leave the sensor out of the spare, or the battery could be dead in it. Here's a little more from the FSM:
"The wheel sensor shall monitor tire pressure, air temperature inside the tire, wheel acceleration and the sensor internal battery status for all four active road tires and the spare tire, if so equipped. The sensor will broadcast this information, along with a unique 32 bit ID, to a central receiver circuit located inside the WCM. The information received by the WCM will be decoded and stored in (RAM) memory in the WCM. The WCM will send bus messages to the re-configurable display module to display the pressures of the four active road tires in vehicle position. The spare tire pressure is monitored but it is not displayed."
"The WCM shall continuously monitor for the receipt of tire pressure RF message transmissions from the wheel sensors during both the ignition key "on" and key "off" cycles. The wheel sensor IDís and the location of each sensor (e.g. Left Front, Right Front etc.) are stored in the WCM non-volatile memory during the initial Manufacturing Plant Process, or during a service procedure, as required."
post #7 of 7 Old 02-25-2020, 03:21 PM
CommanderRandy
2007 XK Commander
This is great info, thanks.
