Aftermarket stereo - JeepForum.com
 1Likes
  • 1 Post By technik
post #1 of 3 Old 07-14-2016, 07:55 AM Thread Starter
2007laredowk
2006 WK
Aftermarket stereo
Is it possible to install an aftermarket stereo with the Boston Acoustics Speakers and amp?, Will that setup work without cutting or splicing wires?, Maybe just the adapter for the stereo but without the need to cut wires.
I fit works and if the stereo has the RCA output available, Can I install a subwoofer without messing with the speakers?, It would be just the Subwoofer RCA output that I would be using.
I've heard people say to just install an aftermarket amp to power some new speakers and leave the stock amp unused and remove the stock speakers but once you start to do that more and more things come up to install and it will get pricey very quickly. The stock speakers sound good enough for now, maybe later I will change them but right now it's the stereo I'm interested in upgrading.
The stereo would be a double din with capability for a backup camera if that matters, and the truck is an '06 Limited WK.
2007laredowk is offline
post #2 of 3 Old 12-01-2016, 08:56 PM
patrick_lyons
Check out Crutchfield. They have a lot of good quality audio parts and they check for compatibility and fitment. They send free installation hardware and detailed spec sheets covering your whole jeep's audio system. In my jeep I have a pioneer touch screen head unit which has a sub out, rca in (for backup cam), and you don't need to cut any factory wires. Im installing my sub this weekend and I'll give you any updates if need be
Sent from my iPhone using Tapatalk
patrick_lyons is offline
post #3 of 3 Old 12-02-2016, 07:31 AM
technik
technik's Avatar
2007 WK
If you have the Boston system, you will need the Canbus adapter between your aftermarket stereo and the Jeep's amplifier in order for it to function. Crutchfield sells the part, or you can look it up there and find it on Amazon. It is a plug and play system with the exception of having to connect your stereo's wiring harness to the adapter. No factory wiring is cut.
They also have a version of the adapter that allows you to retain your factory steering wheel controls, but it costs a little more.
bensylrm likes this.
'07 WK Laredo 4.7L QTII | Silver WK Club Member #143
'07 Compass 2.4L 4x4
'98 Cherokee 4.0L 4x4
technik is offline
sound system , speakers , stereo
