ABS/ Traction Control with Lift Question - JeepForum.com
 1Likes
post #1 of 16 Old 12-06-2019, 10:53 AM Thread Starter
Raffish
2005 WK
Does everyone with a lift press the traction control button to turn it off every time you drive?
I can't go around a corner without the ABS(?) kicking in. It's the worst trying to make 90° to jump into traffic.
Is there a fix to this other than turning it off all the time?
I'm running 265/70/17 on OME and have nOt re calibrated for the larger tires...
You're all awesome.
Your Jeeps are awesome
Your hats are awesome
TIA
05 WK Limited 5.7, QDII, OME HD, 265/70/17 1.25" Spydertrax, CC, MBRP SS, 250xxxkms
Raffish is offline
post #2 of 16 Old 12-06-2019, 11:50 AM
SKALA308
2009 WK
hi Raffish, running on 255/65/17 with OME lift and no problem
2009 WK Overland 5.7 hemi. OME 2" lift, cats removed, free flow with harmonics chamber
SKALA308 is offline
post #3 of 16 Old 12-06-2019, 11:51 AM
Lenny7
2006 WK
Lenny7 is offline
post #4 of 16 Old 12-06-2019, 12:29 PM Thread Starter
Raffish
2005 WK
Is re calibrating my tire size the issue?
I thought that only affected the odometer and speedo...
Raffish is offline
post #5 of 16 Old 12-06-2019, 02:29 PM
underscore
2007 WK
OME MD here with 255/75R17 tires and no issues with any of the "safety" systems. Have you ever done your wheels bearings? A noisy bearing or old/dirty ABS sensor might cause it to be overly aggressive. Is it the same turning both ways or worse one way than the other?
07 WK CRD//QDII//OME MD//MALONE 1.5//OMG WTF BBQ
underscore is offline
post #6 of 16 Old 12-06-2019, 03:00 PM Thread Starter
Raffish
2005 WK
Both hubs are new.
Happens turning both ways.
Does not happen with traction control turned off.
Happens on high speed turns sometimes like highway off-ramps, feels like its coming from the front outer side of turn, but trying to jump into traffic is the worst.
Raffish is offline
post #7 of 16 Old 12-06-2019, 07:26 PM
JeepN_A_CJ7
JeepN_A_CJ7's Avatar
1980 CJ7
Exactly what @Lenny7 said, contact @Kolak and get you a SL EGR module to eliminate this problem. It's common with "most" lifted 2" and up GC's.
You're all awesome.
TIA
Always Jeepin!
*2007 WK QDII HEMI
*1980 CJ7 4.2L w/FAST FI
Silver WK Club
JeepN_A_CJ7 is offline
post #8 of 16 Old 12-10-2019, 10:37 AM Thread Starter
Raffish
2005 WK
So I used the Jscan app ($28) and an ELM dongle to change tire size and now there's no signal from my front left wheel and ABS, traction and SERVICE ELEC BRAKE SYSTEM all displayed...
Going to have a poke around tonight but its weird the wheel signal disappeared right after I changed the tire size...
Will report any changes..
Raffish is offline
post #9 of 16 Old 12-10-2019, 11:47 AM
gargoyle91
Yep I have a 06 Commander and have to turn it off every time I drive it's habit now The key is to hold it down until you hear a ding , if you just push it some reason it really doesn't turn it off but it shows off .
gargoyle91 is offline
post #10 of 16 Old 12-11-2019, 03:48 PM Thread Starter
Raffish
2005 WK
I did manage to activate the side mirrors tilt down when in reverse and one touch lane change (turn signal flashes 3 times with one touch) features, both of which I really like..
JeepN_A_CJ7 likes this.
Raffish is offline
post #11 of 16 Old 12-12-2019, 02:20 PM Thread Starter
Raffish
2005 WK
Live data shows the front left wheel isn't sending any signal, causing U0415, which is causing the front diff to be confused and throwing C141B. I think.
Strange that the wheel sensor quit right when I changed tire size (with Jscan app)...
I have an old sensor from a replaced hub that I'll try.
Raffish is offline
post #12 of 16 Old 12-12-2019, 02:31 PM
underscore
2007 WK
Did you check for codes before changing the tire size? I'm wondering if a bad sensor or wire was the problem all along.
post #13 of 16 Old 12-13-2019, 12:36 PM Thread Starter
Raffish
2005 WK
There were no lights on or drivability issues before I ran the app but there could have been pending codes I guess.
I swapped the sensor last night and everything seems to be working now, no codes on the way to work, nothing pending and tire size set to 31.5"
Sweet!
But...
Noticed my coolant res was empty, wtf, there was a drop on the bottom corner of the rad. Couldn't see any leaks anywhere else so I guess the rad is leaking (?). Filled it up and its holding since last night anyway...
No rest for the wicked I guess....
Raffish is offline
post #14 of 16 Old 12-14-2019, 05:47 PM
clemsonscj
Originally Posted by Lenny7 View Post
Is this necessary even with just the 2" OME lift and slightly bigger tires?
'09 GC Overland 5.7L QDII; OME HD Lift; 265/70R17 Ridge Grapplers; SC Flashpaq
Black WK Club #134
clemsonscj is offline
post #15 of 16 Old 12-16-2019, 08:26 AM
Lenny7
2006 WK
That is the setup I have and haven't had any problems without it, other than being off about 3mph.
Lenny7 is offline
