4.7 to 5.7 Hemi Swap - JeepForum.com
 3Likes
  • 1 Post By kevinjackredd
  • 2 Post By yzjwk
post #1 of 7 Old 07-19-2021, 04:36 PM Thread Starter
kevinjackredd
2005 WK
Hello everybody,
I'm thinking about swapping a 5.7l into my 2005. 4.7l WK and was wondering if the transmissions match or what I may need. Do they both share the 5-45RFE transmissions?
sgossler likes this.
Last edited by kevinjackredd; 07-19-2021 at 04:39 PM. Reason: year was not specified.
kevinjackredd is offline
post #2 of 7 Old 07-19-2021, 06:07 PM
sgossler
2005 WK
I want to know too. I have a reliable 4.7 rig, thats whats holding me down. I do wish it had more power on the highway, but thats it.
2005 Jeep GC Limited 4.7 QTII
2.3" RRO lift Bilstein Struts/Shocks 255/70R17 Cooper AT3
sgossler is offline
post #3 of 7 Old 07-19-2021, 06:25 PM
90grandoneer
90grandoneer
90grandoneer's Avatar
2006 WK
4.7 and 5.7's use the 545RFE transmission.
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, AFE Air Filter, 6spd 545RFE, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, DS and HP tuners, Transgo Shift Kit, ARH Long Tube Hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam w/6* advance/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, TEA ported/milled heads w/new valve seats, SRT Reps with 265/45&295/40X20's. Also 05 Hemi LX modded exactly like WK and, SOLD Comp Cammed 06 300CSRT8 just replaced with 2021 Tesla Model S Plaid with 1020 hp and 1050 lb. ft. of torque.
90grandoneer is offline
post #4 of 7 Old 07-20-2021, 05:26 PM Thread Starter
kevinjackredd
2005 WK
From what I've read, yes they both share transmissions and exhausts.
You will need a 5.7 engine harness, motor mounts, tuner, fuel line, but I'm not sure what else. Do check the bolt pattern for your 545RFE or if you will need a different torque convertor.
post #5 of 7 Old 07-20-2021, 06:00 PM
90grandoneer
90grandoneer
2006 WK
The cat. back is probably the same, but from the exhaust manifolds to the cat. back (the Y pipe) is different. I doubt the 4.7 and 5.7's share the same exhaust manifolds but, then again, I am not that familiar with the 4.7's.
post #6 of 7 Old 07-20-2021, 06:17 PM
yzjwk
yzjwk's Avatar
2005 WK
If you want factory integration, youíll need complete wiring harness, PCM, cooling system, brake and ABS system, TIPM and FCM.
Itís honestly cheaper and easier to just sell yours and buy one with a hemi.
sgossler and kevinjackredd like this.
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #7 of 7 Old 07-21-2021, 10:06 PM Thread Starter
kevinjackredd
2005 WK
Yes my mistake, everything from the muffler forward will need to be swapped out apparently. Including the manifolds.
4.7l wk , 5.7 hemi
