255 70 17 with moabs - looking for experience/feedback - JeepForum.com
 3Likes
  • 1 Post By Zroe89
  • 1 Post By nvrdone1
  • 1 Post By jeeptorino68
post #1 of 6 Old 09-23-2021, 08:01 AM Thread Starter
jeeptorino68
1992 XJ Cherokee
Looking for some input from anyone who has run 255 70 17 on moabs.
I am tenatively planning this combo. Have a 1.5 inch lift already installed. And wheel spacers ready. I think I'll need the spacers because of the Moab wheels....
Thanks!
Kyle
92 XJ 4.0 HO,AW4, NP242, 30" BFG AT, 1.75 spacer and ZJ coils, double cherokee leaf pack and 2 inch rough country shackles, 2.5 inch dnynomax exhaust, magnaflow cat, front hooks & rear hitch, gas skid, front skid, warn t-case skid, 99+ intake, bored TB
02 KJ Limited, 255 70 16s, front skid, LS/373 gears
jeeptorino68 is offline
post #2 of 6 Old 09-23-2021, 12:20 PM
Zroe89
Not sure how much different the offset was between the moans and the newer Rubicon wheels with the Willy's Jeep logo on them but my 255/70r17 Toyo AT2s fit well with no spacers on my 2" lift. I'm running RRO spacers up front and OME med springs in the rear.
The other nice part about the 255/70r17 is that with a little effort to smooth out the trailer hitch bracket they fit up underneath as a full size spare.
Sent from my moto g stylus using Tapatalk
jeeptorino68 likes this.
Zroe89 is offline
post #3 of 6 Old 09-24-2021, 08:10 AM
nvrdone1
2007 WK
Ive got 255 / 65 / 17 geolanders on my '07 overland with JK moab's. dont know what the difference is between a 65 and 70 series, but mine fit great. only needed a 1/8" spacer on the front to clear the caliper bracket. No lift.
nvrdone1 is offline
post #4 of 6 Old 10-10-2021, 07:13 PM Thread Starter
jeeptorino68
1992 XJ Cherokee
Well. Got em and they fit. The usual needs for moabs. Sanding down the caliper bracket etc. A small spacer would be nice. But the tires fit.
Kyle
post #5 of 6 Old 10-13-2021, 05:17 PM
PuffBlueCat
This is the exact wheel/tire combo I am looking at for my 2008 wk. Besides sanding down the caliper bracket, was their anything else you needed to do to make the wheels fit? Also I was wondering where exactly I needed to sand, or if it would be obvious once I test fit the wheel. Any help is appreciated.
PuffBlueCat is offline
post #6 of 6 Old 10-14-2021, 08:16 AM Thread Starter
jeeptorino68
1992 XJ Cherokee
It will be obvious when you put the wheel on. But when you remove your wheel. And are facing the disc brake system. There is a curved bracket that will be closest to you. As part of the casting process there is a raised "seam". Sand that seam down. And test fit until you have clearance. You need to tighten the wheel on all the way each time to check the fitment.
PuffBlueCat likes this.
Kyle
