2009 grand cherokee starting problem - JeepForum.com
post #1 of 67 Old 04-16-2012, 06:47 PM Thread Starter
jpm6621
Can i post a video on here? My 2009 GRAND CHEROKEE won't start sometimes. I go and turn it over and it makes like a cha cha cha cha sound for about 7 seconds (best way i can describe it), at about 500 rpms until it shuts off. Then sometimes it will start but it doesn't sound RIGHT when it fires up, to me it sounds like an exhaust leak when it DOES start. Anyone else have this problem?
jpm6621 is offline
post #2 of 67 Old 04-17-2012, 07:36 PM
HEMI35
2007 WK
Hi man, I had EXACTLY the same problem when I bought my 2007 JGC HEMI.
Took it to service and they changed the battery and the coals of the starting engine (the electrical starting small engine). After that, it started with no problems AT ALL making that HEMI beast starting sound I love.
After many months, I have no issue with the start anymore.
HEMI35
HEMI35 is offline
post #3 of 67 Old 04-18-2012, 06:02 AM Thread Starter
jpm6621
Im guessing you meant COILS, unless your Jeep runs on coal? And what do u mean electric starting small engine?
jpm6621 is offline
post #4 of 67 Old 04-18-2012, 07:06 AM
modernblueWK
The starter motor
SOLD 2008 WK 4.7 V8
2013 Hemi Durango Crew
2007 Silverado Crewcab LT3
modernblueWK is offline
post #5 of 67 Old 04-18-2012, 05:03 PM
HEMI35
2007 WK
Yep, the starter motor. And yes, I meant coals (they disassembled the starter motor, and replaced the coals inside). Cheaper than buying a new starting motor.
HEMI35
HEMI35 is offline
post #6 of 67 Old 04-19-2012, 07:08 AM
modernblueWK
Did they replace the starter selenoid? Still no coals....
SOLD 2008 WK 4.7 V8
post #7 of 67 Old 04-19-2012, 08:35 AM
yzjwk
yzjwk's Avatar
2005 WK
I think he means the brushes in the starter . They probably put a rebuild kit in .The main failing point on these starters is the attached solenoid ,which i don't think is replaceable .
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #8 of 67 Old 04-20-2012, 12:53 PM
HEMI35
2007 WK
oh, sorry, I called a mechanic friend, he told me "they call them coals, they're are not coals!!!" hahaha, my bad.
He told me that the part you have to replace are the brushes. No rebuild kit, they did it in an electric garage for cars.
My friend sent me this video:
at the beginning, you can hear he says "carbones" (spanish for coals), and he refers to the brushes 0:03. The video is in spanish, though, and I'm not mexican so it's difficult to understand some of the terminology he uses to refers to some parts. The thing is, if you put "electric starter brushes" on ebay you'll get the things to replace, the problem is to find the correct ones for the GC
HEMI35
HEMI35 is offline
post #9 of 67 Old 04-22-2012, 03:49 PM
HEMI35
2007 WK
I forgot to add that they also changed the battery; previous owner put a wrong battery, and they put the battery for a 07 GC HEMI (I don't know if it is the same battery for a 4.7 or 5.7 engine)
HEMI35
HEMI35 is offline
post #10 of 67 Old 04-22-2012, 04:23 PM
AJeepZJ
AJeepZJ's Avatar
2006 WK
To my knowledge, it doesn't matter too much what battery it has just as long as it has enough cranking amps to start everything in stock form.
All Gear, No Skill.
AJeepZJ is offline
post #11 of 67 Old 10-23-2012, 02:32 PM Thread Starter
jpm6621
Still the same starting problem
My jeep wouldn't start one morning at all just clicked so i had a new starter installed and that fixed THAT problem. I took it to a garage for my initial problem and they told me it was the throttle body so i ended up replacing that. That was months ago and now the same starting issue is back. Turn the key, you a get cha cha cha cha cha noise idling at about 400 RPMS until it quits. Does not do this every time tho. When it does tho, the electronic throttle control light is on. To me it almosts sounds like a misfire or something along those lines. I took a short video when it did it so who ever knows what they're talking about can tell me EXACTLY the issue!
jpm6621 is offline
post #12 of 67 Old 10-26-2012, 11:41 AM Thread Starter
jpm6621
Well mechanics gunna change the Cranshaft Position Sensor today. We"ll see if that fixes the starting problem.
jpm6621 is offline
post #13 of 67 Old 11-01-2012, 09:33 AM Thread Starter
jpm6621
Well a new Crankshaft Position Sensor did nothing. No codes, computer says everything is normal yet the problem is still there. Brand new starter also.
jpm6621 is offline
post #14 of 67 Old 11-11-2012, 10:19 AM
HEMI35
2007 WK
battery...
HEMI35
HEMI35 is offline
post #15 of 67 Old 11-11-2012, 05:10 PM Thread Starter
jpm6621
I had the battery and alternator tested and they are fine, even though both are Original as far as i know. I bought the Jeep with 32,000 miles, i now have 103,000 miles.
jpm6621 is offline
2009 Grand Cherokee Windows down from Key Fob? Peasey WK Grand Cherokee & XK Commander Forum 7 06-06-2012 08:18 AM
265 60 18 or 265 50 20 tire's on Grand Cherokee 2009 ( WK ) apood WK Grand Cherokee & XK Commander Forum 4 04-03-2012 07:22 AM
97 grand cherokee starting problem D3V0311 ZJ Grand Cherokee Forum 15 02-05-2011 05:47 PM
2009 Grand Cherokee Question engine5 WK Grand Cherokee & XK Commander Forum 0 05-30-2010 08:08 PM
2009 Grand Cherokee gsxr150 WK Grand Cherokee & XK Commander Forum 15 07-13-2008 08:42 PM
