2008 Jeep Cherokee Laredo - fluid service "Quantities?" - JeepForum.com
 12Likes
post #1 of 25 Old 06-14-2021, 02:53 PM Thread Starter
riderboy1961
riderboy1961's Avatar
2008 WK
I have a 2008 jeep cherokee laredo 4.7l w/ NV245 transfer Case
In the Owners Manual it states what Types of fluid for each hole but not "How Much" per hole.
Can anyone give me the quantities to put in each hole when servicing?
1) Front Differential
2) NV245 Transfer Case
3) Rear Differential
Thank You
Thank You,
Bo
riderboy1961 is offline
post #2 of 25 Old 06-14-2021, 04:24 PM
DarkSideofWill
http://wkjeeps.com/wk_maintenance.htm
I'm new to WK's, but this looks like it has everything.
Typically for a gearbox with a fill port, like the front diff, T-case and rear axle, you just make sure the vehicle is level, then fill until the fluid level inside gets to the level of the fill port
DarkSideofWill is offline
post #3 of 25 Old 06-14-2021, 05:18 PM
caulk04
2008 WK
Get 2qt for the tcase.
Get 4qt to do the diffs.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #4 of 25 Old 06-14-2021, 06:10 PM Thread Starter
riderboy1961
2008 WK
Great Site DarkSideofWill !!
and... Thank You caulk04 !!
Thank You,
Bo
post #5 of 25 Old 06-15-2021, 08:56 AM
DarkSideofWill
Of course also need to make sure you have the limited slip additive in the diff & axle.
post #6 of 25 Old 06-15-2021, 11:11 PM Thread Starter
riderboy1961
2008 WK
Yes, I read online it is a 4oz bottle of additive - goes in the Rear Diff Only, from what i have read - so that means we have a locker or limited-slip in the rear which could be handy in some terrain.
Thank You,
Bo
post #7 of 25 Old 06-16-2021, 01:02 AM
underscore
You need the additive in the front and the rear, but only if you have QuadraDrive II.
Brit30-06 and riderboy1961 like this.
00 WJ
[x] 07 WK CRD/OME/MALONE 1.5 [x] 00 XJ/OME [x] 97 TJ [x] 92 YJ
underscore is offline
post #8 of 25 Old 06-17-2021, 09:28 AM
DarkSideofWill
If OP has the NV245, then he has QDII, right?
post #9 of 25 Old 06-17-2021, 02:11 PM
acabtp
2005 WK
not necessarily
NV140 transfer case + open axles = Quadra-Trac I
NV245 t.c. + open axles = Quadra-Trac II
NV245 t.c. + elsd axles = Quadra-Drive II
Brit30-06 and underscore like this.
'05 WK Limited 5.7 Hemi
acabtp is offline
post #10 of 25 Old 06-17-2021, 05:56 PM
underscore
Going from memory I believe Quadra-Trac refers to the two different tcases and Quadra-Drive refers to the axles. So you may see both listed on the build sheet.
If you have QDII you have an NV245, but having an NV245 doesn't guarantee QDII, if that makes sense.
Brit30-06 likes this.
00 WJ
post #11 of 25 Old 06-17-2021, 07:11 PM
Brit30-06
2008 WK
Underscore is correct.
For example, i have NV245 TC but have open diffs front and back. QT2.
underscore likes this.
Brit30-06 is offline
post #12 of 25 Old 06-17-2021, 08:38 PM
19GCTrailhawk
19GCTrailhawk's Avatar
2019 WK
2008 Laredo 4.7L Quadra Trac II doesn't get Quadra Drive II
2019 Grand Cherokee Trailhawk 5.7
Grand Cherokee Owner since 1994
19GCTrailhawk is offline
post #13 of 25 Old 06-18-2021, 06:05 AM
Brit30-06
2008 WK
FWIW.
In my open QT11 Diffs i use Amsoil 75w-140 synthetic severe gear.
My NV245 has Petronas Power Gear 4. This is what UK Jeep dealers use. Amsoil have an equivalent product.
post #14 of 25 Old 06-18-2021, 10:01 AM Thread Starter
riderboy1961
2008 WK
Interesting!!
I am learning something new right now - I did Not read about that these could have a quadra-trac II <or> quadra-drive II.
I have a copy of the Build Sheet, these are some things that are on the build sheet, written exactly as it is on the build sheet...
Quadra_Trac II Full-Time, Active 4WD
Four Wheel Drive (4WD)/(4X4)
200MM Front Axle
213MM Rear Axle
Conventional Differential Frt Axle
Conventional Differential Rear Axle
4.7L V8 Engine
5-Spd Automatic 545RFE Transmission
3.73 Rear Axle Ratio
Trailer Tow Group IV
Does this rig have Open, Limited Slip or Locking differential(s)?
***I do Not see: quadr-drive II written on my 6 pages of build sheets.
Thank You,
Bo
post #15 of 25 Old 06-18-2021, 10:26 AM Thread Starter
riderboy1961
2008 WK
Ok... I just ran across some info on this site from some years back, on Another Way how to tell.
12 bolt rear diff cover = QDII
10 bolt rear diff cover = QTII
My rig has the 10 bolt rear diff cover
My vehicles Build sheet does Not read: Limited Slip nor Locker so I can probably assume this rig has Open Differentials?
Thank You,
Bo
