2008 CRD fuel tank removal. - JeepForum.com
post #1 of 13 Old 09-25-2015, 08:01 PM Thread Starter
albertajeep
2008 WK
We have a 2008 GC CRD, I have heard a from a few owners locally that drive one, that they had to replace their fuel tank due to rot.
I crawled underneath the jeep to have a look and see if I can remove the tank skid plate, and clean out the dirt between the skid plate and tank, but is skid plate also holding the tank up? Is there a step by step instruction somewhere on how to remove this?
I just want to be ahead of the game, as I heave heard it is not cheap to replace these fuel tanks , and they are hard to come by.
Our Jeep has 149000km on it, and I've heard that they spring leaks at around 160-180000km .
albertajeep is offline
post #2 of 13 Old 09-25-2015, 10:11 PM
Red_liner740
Search, its been covered. 7 bolts, two fuel lines front, connector, fill and vent hose in the back.
Red_liner740 is offline
post #3 of 13 Old 09-30-2015, 10:38 AM
robhegedus
2007 WK
I just finished up sealing my tank with a POR15 fuel tank repair kit. What a pain in the *** to do on these tanks. The dealership has the balls to charge $2000 for a new tank. Pissed me right off. There were multiple pin holes in the tank when I got all the rust/paint cleaned off.
I only recently completed the job and haven't even filled the tank back up yet, but as far as I can tell, it is a good product and is a viable option...it just takes a lot of time to do. And you'll have silver coating on your hands and arms for days or weeks if you're not extremely careful....there's still some on my fingernail that I can't get off and it's been about a month since I did the job. I figure it must be a damn good coating.
If I were to do it again, or even as a preemptive measure, I would definitely remove the tank, clean up the exterior really well, then put either a coating of bedliner or even a coat of POR rust paint on it. I used some rubberized asphalt undercoating, and I think this was not the right move...it never really cured and I don't know how well it will actually protect the tank in the future.
robhegedus is offline
post #4 of 13 Old 09-30-2015, 05:45 PM
ggrassmid
2008 WK
I did mine with Chassis Saver at the same time I did the entire bottom of my Jeep. I would not want to do this ever again. I do, however, want to do the POR15 inside fuel tank sealer in the near future to make sure I have both sides of mine covered. Mine was not leaking, so I am trying to be proactive on it.
I prepped everything like the POR15 directions, but used Chassis Saver paint instead of POR15. I would recommend someone to make sure they prep well and do an exception job using the POR15 Metal Prep so that the next step really adheres well.
ggrassmid is offline
post #5 of 13 Old 09-30-2015, 06:18 PM
Tango.
The cheapest way is cover it with waterproof marine grease.
Life is hard-John Wayne
Tango. is offline
post #6 of 13 Old 09-30-2015, 06:56 PM
Hendrix9
2007 WK
I would think diesel's oily nature would prevent internal rust from forming. I'd be nervous putting any kind of paint inside the tank. Just my opinion.
I really need to drop my tank and be proactive, but i really dont want to do it... Lol
2007 CRD QDII
2004 QD 4.7 GC
2009 Rav4 v6
2009 Sienna
Hendrix9 is offline
post #7 of 13 Old 10-02-2015, 06:56 PM Thread Starter
albertajeep
2008 WK
Well I removed the tank, it wasn't leaking yet, but I too I want to be ahead of the game and clean everything before it starts leaking.
As it turns out, the back part of the skid plate was full with dirt, so I cleaned everything off, used a wire brush to clean off the rust and dirt off the tank, and lone behold I see a little pinhole, tilted the tank and what ever fuel was left in there it started too pee out. Wonderful.
Well I guess I have to go and get some of that tank repair goop
I did notice that the back righthand corner of the tank is all pitted.
I am surprised with so many leaking tanks that those jeeps have not been recalled.
post #8 of 13 Old 04-10-2017, 03:01 PM
WK2K8
How did you remove the front inner bolt under the propshaft?
WK2K8 is offline
post #9 of 13 Old 04-10-2017, 03:25 PM
ggrassmid
2008 WK
Adjustable angle ratcheting end wrench.
post #10 of 13 Old 04-10-2017, 05:07 PM
Vancity
2008 WK
Or disconnect the rear of the driveshaft and swing it out of the way
Vancity is offline
post #11 of 13 Old 04-10-2017, 09:07 PM
ech0sh4y
2008 WK
Just did this, I waiting until the low fuel light came on, then looked at the miles remaining and waited until that said LOW FUEL LEVEL... had about 2-3 gallons at that point. I couldn't believe the amount of rust in between the skid plate layers. The tank wasn't too bad but did have a fairly rusty spot. I used the undercoating and rust stop. I also changed the foam out for new stuff. I can't believe how expensive these tanks are. What a joke!
~ Brian
2008 WK Overland CRD
ech0sh4y is offline
post #12 of 13 Old 04-10-2017, 11:06 PM
underscore
Has anyone swapped a plastic tank from a gas WK into a CRD? Is diesel harmful to the plastic or something?
00 WJ
[x] 07 WK CRD/OME/MALONE 1.5 [x] 00 XJ/OME [x] 97 TJ [x] 92 YJ
underscore is offline
post #13 of 13 Old 04-15-2017, 10:21 AM
suzieque
2008 WK
damn, I'm not looking forward do doing this job, but it will need to be done.
did you guys install some pad or matting between the tank and skid plate now?
I wonder if there is a way to leave the tank installed but drop the skid plate.
original thread on this topic
https://www.jeepforum.com/forum/f67/r...-tank-3106977/
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
