2008-2010 WK HID lighting upgrade - JeepForum.com
 1Likes
post #1 of 16 Old 01-23-2020, 07:54 AM Thread Starter
Gray203m
2008 WK
Has anyone with a 2008-2010 WK upgraded to HID headlights? I have factory halogen housings and swapped LEDs into the low beams when I purchased the Jeep. I've since come to realize that they are terrible and I want to upgrade.
I know the easiest/cheapest upgrade would be to a 9011 for the low beam, but I really prefer the look of a more pure white/white-blue light.
So has anyone swapped to HID projectors? Did you use OEM housings? Aftermarket? Retrofit projectors into halogen housings or cheap aftermarket housings? Were you happy with the outcome?
2008 WK CRD North
GDE Eco Tune, DPF Delete
2" RC lift, 265/65R18 Duratracs
Gray203m is offline
post #2 of 16 Old 01-23-2020, 08:29 AM
08zombie
08zombie's Avatar
2008 WK
I personally went the overcomplicated retrofit route here (the pictures are all gone after that photobucket disaster but the text is still there): https://www.jeepforum.com/forum/f67/...oject-3396850/
I'm thrilled with how mine came out. It's not a HID retrofit but it fits the bill. I'll see if I can post a photo.
I've posted this a few times around here but here's some info:
Use a set of 2008-2010 OEM (or OEM replica) headlights. You'll need to buy the following: Headlights, Valeo Ballasts (2), D1s Bulbs & Relay Harness w/ capacitor (the PWN system on the Jeeps requires this).
The replica headlights (made by brands like TYC and Eagle Eye) use subpar projectors. They do the job but the projector bowl is not as reflective as the OEM Valeo projectors. Make sure the headlights are bulb type "D1S". A lot of folks buy the Spyder projector headlights and use HID bulbs in them. That's the wrong thing to do because the Spyder lights are designed for halogen bulbs (H1).
Bangarng likes this.
Check My Threads For These Builds:
WK LED Headlight Quad Retrofit
WK Morimoto LED Foglights
08zombie is offline
post #3 of 16 Old 01-23-2020, 08:31 AM
08zombie
08zombie's Avatar
2008 WK
If the images above don't work please let me know!
08zombie is offline
post #4 of 16 Old 01-23-2020, 08:46 AM Thread Starter
Gray203m
2008 WK
I just looked at the thread. Results sure look great, but that's way too time intensive for my current level of free time
Ya I looked at a lot of those replicas and most actually say for halogen. I've also read that the size and shape of the projector, lense, and cut-off is significantly different between a halogen projector and a HID projector. That being said, I feel like these cheap halogen projector housings would make for a faster HID or LED projector retrofit
2008 WK CRD North
Gray203m is offline
post #5 of 16 Old 01-23-2020, 08:54 AM Thread Starter
Gray203m
2008 WK
Images came through. Those look amazing, and I love the halogen projector for the high beam
2008 WK CRD North
Gray203m is offline
post #6 of 16 Old 01-23-2020, 08:59 AM
08zombie
08zombie's Avatar
2008 WK
Thanks! It took quite a bit of time. I went Halogen high beam honestly because it's super easy.
Replicas like this are HID: https://www.1aauto.com/2008-10-jeep-...=580374&y=2008
Size/shape/lens/cutoff shield are definitely different from HID to Halogen. Almost every HID projector is different from one another too. They all have different properties (cutoff/hotspot/width).
If you like the style of the Spyder lights then you could definitely open them and swap the projectors out. TRS makes a kit (But I'd contact them and see if you can use the better quality Morimoto projector and not the ACME stuff): https://www.theretrofitsource.com/mo...ik-spyder.html
Someone makes an OEM HID lookalike that has a 9006 halogen projector inside. I can't find them right now but you could always use one of those too.
08zombie is offline
post #7 of 16 Old 01-24-2020, 07:44 AM Thread Starter
Gray203m
2008 WK
So the more I research parts and look through your conversion, the retrofit option is starting to look better and better. To get oem headlight assemblies/bulbs/ballasts and wiring I'm looking at least $600 CAD.
Usings an aftermarket halogen projector like this:
http://rover.ebay.com/rover/0/0/0?mp...2F193254301867
With either the spyder retro-quik:
http://www.theretrofitsource.com/mor...C54403%2C47308
Or mini-h1 retro-quik:
http://www.theretrofitsource.com/mor...universal.html
Would be a little cheaper, and probably provide better lighting (maybe?) And not take a whole lot more time to build.
What're your thoughts?
2008 WK CRD North
Gray203m is offline
post #8 of 16 Old 01-24-2020, 08:04 AM
08zombie
08zombie's Avatar
2008 WK
Looks like you've nailed it! It'll definitely provide much better light output.
My advice would be to buy just the assemblies first. That way you can open them up and use the halogen projector for measurements (Honestly you could try out the lights with Halogen bulbs and see how you feel... It might be exactly what you're looking for without additional work). Also it can be frustrating at times during a retrofit project like this so take it slow. Join up at HIDPlanet.com for additional resources (I'm over there too).
I do my best to answer PMs and the guys at TRS are extremely knowledgeable and should be able to help you out too.
08zombie is offline
post #9 of 16 Old 01-24-2020, 08:15 AM
08zombie
08zombie's Avatar
2008 WK
I sent you a PM just now. Let me know if it didn't go through (It's not showing up in my sent folder).
08zombie is offline
post #10 of 16 Old 01-24-2020, 08:20 AM Thread Starter
Gray203m
2008 WK
PM came through. Thank you for that. I did message the guys at TRS asking about some options.
These cheap housings I'm looking at aren't certified for on road use, so I'm betting the reflectors aren't awesome and only really for show. I do mostly highway driving and probably 3/4 of that is in the dark, so the actual light output is fairly important lol
2008 WK CRD North
Gray203m is offline
post #11 of 16 Old 01-25-2020, 08:34 PM
Bangarng
2010 WK
That's what I did and wish I did it correctly. Listen to 08Zombie, spend a little extra and do it correctly.
H1 HIDS in Halogens aren't terrible but there is some scatter so I have to point them lower to avoid being 'that guy'.
Bangarng is offline
post #12 of 16 Old 01-26-2020, 12:36 PM Thread Starter
Gray203m
2008 WK
I ended up ordering these lights, and once they arrive i'll take the projector out and measure it so I can order retro-fit bi-xenon projectors from TRS
2008 WK CRD North
Gray203m is offline
post #13 of 16 Old 06-12-2020, 11:49 AM
wbrown85
2011 WK
Has anyone on here used the factory assemblies and wiring and swapped these into a jeep with halogens? From what I have been researching it looks like they drop right in. All you need to do is a bit of splicing on the harness connectors. Has anyone done this? Is this true?
Thanks!
wbrown85 is offline
post #14 of 16 Old 06-13-2020, 06:11 AM Thread Starter
Gray203m
2008 WK
Thanks!
I thought about going this route. Unless you can find a decent price on an entire used assembly, the price isn't much different than building your own, and you get better light output building your own.
The wiring isn't that bad and I can give you a hand with it if you decide to go that route.
2008 WK CRD North
Gray203m is offline
post #15 of 16 Old 06-14-2020, 09:09 AM
brent_m
2007 WK
Does this mod impact the auto-high beam functionality on some of the WKs? I'm considering it myself. I've run out of Covid-19 projects.
2007 Jeep Grand Cherokee Overland
5.7 Hemi - Airaid CAI - Magnaflow
brent_m is offline
