2007 Jeep Commander Shifting issue NEED HELP ASAP - JeepForum.com
post #1 of 10 Old 12-14-2017, 03:05 PM Thread Starter
jws123
I have a 2007 Jeep Commander 3.7 4x4 it runs drives and shifts fine but today i started it engine light came on was a code for shift module and trans temp sensor? I reset it jeep still shifts and drives fine how ever i can use the gear limiter when i hit it left or right nothing happens i took it apart cleaned contacts reset battery but it still wont do it any suggestions? I dont want to replace the shift Module if it is not the issue.
On a side note When i make a sharp right or left turn i get a grinding noise in the front like the tires rub but they dont what could it be?
jws123 is offline
post #2 of 10 Old 12-14-2017, 04:44 PM
underscore
2007 WK
I know the trans temp warning comes up a lot as the battery is getting weak, so maybe have it tested. As for the front end grinding it may be one or both wheel bearings starting to go.
07 WK CRD//QDII//OME MD//MALONE 1.5//OMG WTF BBQ
underscore is offline
post #3 of 10 Old 12-14-2017, 04:52 PM Thread Starter
jws123
i will check on the battery i mean it starts up fine and both wheel bearings are good its weird its only when u take a left or right turn harder. it grinds like a wheel rub but they dont rub
jws123 is offline
post #4 of 10 Old 12-14-2017, 04:58 PM
jtec
jtec's Avatar
2014 JK Wrangler
tell us the code maybe someone can pull up the troubletree - eliminate the guessing...
jtec is offline
post #5 of 10 Old 12-14-2017, 04:59 PM Thread Starter
jws123
When the code comes back up i will post it has not came back up yet but still cant manually shift.
jws123 is offline
post #6 of 10 Old 12-14-2017, 05:17 PM Thread Starter
jws123
Just ran outside to test battery says its good im at a loss never had this issue before.
jws123 is offline
post #7 of 10 Old 12-16-2017, 07:31 AM Thread Starter
jws123
anyone else have any suggestions of what it would be causing it to not let me manually shift/limit gear.
jws123 is offline
post #8 of 10 Old 12-16-2017, 07:47 AM
jtec
jtec's Avatar
2014 JK Wrangler
The light does NOT come on for all codes.
with your scanner look at Pending codes, also check code History.
jtec is offline
post #9 of 10 Old 12-16-2017, 08:07 AM
RCS1300
2005 WK
Could be your CV axles. Noise on right turn usually means left CV and noise on left turn usually means right CV axle.
What transmission do you have?
Take a look at post #24 -- https://www.jeepforum.com/forum/f67/0...30/index2.html
RCS1300 is offline
post #10 of 10 Old 12-16-2017, 07:03 PM Thread Starter
jws123
yea no codes as of yet its weird only issue rn is i cant manually shift/limit gears its weird truck drives fine otherwise if the code comes back in the next day or so il post it i only reset it yesterday gotta put some miles on it i guess....
jws123 is offline
