2006 Jeep Commander - Rust colored coolant empty and overheating - JeepForum.com
 1Likes
  • 1 Post By jtec
post #1 of 12 Old 07-17-2021, 01:56 PM Thread Starter
duveduve
2002 XJ Cherokee
2006 Jeep Commander - Just purchased in January 2021. Suddenly started overheating - here the coolant was rust colored and it was empty. Took it in to have it flushed and they said they couldn't get it to flush clear. It should be full now (can't tell because fill tank it now stained rust colored) but still overheats within 10 minutes of driving. Guy at Mobil 1 said to trade it in... really?
Not a mechanically inclined car person. What should I check for?
duveduve is offline
post #2 of 12 Old 07-17-2021, 02:08 PM
jtec
jtec's Avatar
2014 JK Wrangler
You should find a technician to assist with your vehicle repairs and maintenance. Choose your technician as you would any other professional be it a physician, attorney or financial advisor, talk to family, neighbors, coworkers and fellow church members for suggestions. Look for ASE certifications for technicians a good BBB rating.
You description sounds like the "mobile one" facility is not up to assisting you with your jeep needs.
222Doc likes this.
jtec is offline
post #3 of 12 Old 07-17-2021, 02:28 PM Thread Starter
duveduve
2002 XJ Cherokee
I'm kind of wondering if this has happened to anyone and what the problem was or what it might be so I have some knowledge when I call another place.
The engine fan does kick on. Also today before it overheated the a/c went warm, then "check guages", and it was all the way to "H"
Thermostat?
Fan relay? (But fan kicks on)
Water pump?
Head Gasket? (please no)
Why does coolant turn rust colored and go completely empty with no visable leaks?
duveduve is offline
post #4 of 12 Old 07-20-2021, 12:59 PM Thread Starter
duveduve
2002 XJ Cherokee
Ok the following things have now been done:
1) New thermostat - still overheating
2) New water pump - still overheating
3) New radiator - still overheating
4) Tested for gasket issues via smoke test - was fine
What am I missing? Any ideas anyone?
duveduve is offline
post #5 of 12 Old 07-20-2021, 01:20 PM
jtec
jtec's Avatar
2014 JK Wrangler
what are the indications of overheat?
temp gauge only?
Coolant boils over quickly?
Are you still loosing fluid (coolant)?
which engine?
jtec is offline
post #6 of 12 Old 07-20-2021, 01:27 PM Thread Starter
duveduve
2002 XJ Cherokee
Temperature guage goes to Hot then "Engine Over Temp Check Guages" flashes on dash
duveduve is offline
post #7 of 12 Old 07-20-2021, 01:29 PM Thread Starter
duveduve
2002 XJ Cherokee
No leaks were determined now after parts replacements. Shop said it is not leaking coolant now. They either felt someone had used "stop leak" at some point or saw evidence of such, not sure which. It was a lot of rambling information after all the work was completed.
duveduve is offline
post #8 of 12 Old 07-20-2021, 02:16 PM
jtec
jtec's Avatar
2014 JK Wrangler
Is the engine reaching overheat quickly, could there be a gauge issue?
You have not mentioned which engine.
Did you use a OEM thermostat ? Again which engine.
jtec is offline
post #9 of 12 Old 07-20-2021, 05:41 PM Thread Starter
duveduve
2002 XJ Cherokee
3.7 liter
Reaches high temp after 20 total minutes (idle time for a bit plus short drive)
No idea on thermostat - it was at Meineke. It says 195f/91c thermostat
duveduve is offline
post #10 of 12 Old 07-21-2021, 07:50 PM
retrvrtrainer
retrvrtrainer's Avatar
I have had similar problems with my XJ. I had to replace the radiator to correct it. Do you know if the hoses were replaced as well? Is there still rust? May be a good time to change the oil and see what it looks like.
Matt 7:7-11
retrvrtrainer is offline
post #11 of 12 Old 07-22-2021, 09:11 AM Thread Starter
duveduve
2002 XJ Cherokee
Oil was changed. Still some rust color to antifreeze. Burped the radiator at an incline for an hour yesterday and it never once overheated at idle while it was burped. Took it for a drive later and overheated within 5 minutes. Oil looks great, not milky.
Oil change done
Thermostat done
Radiator replaced done
Top hose to Radiator was replaced done
Burped radiator for an hour done
Fan kicks on appropriately when at idle. Honestly no idea if it comes on when driving (obviously).
None of this makes sense. The engine is super quiet and smooth.
duveduve is offline
post #12 of 12 Old 07-22-2021, 11:10 AM
jtec
jtec's Avatar
2014 JK Wrangler
attaching some notes -
As you are NOT the origional owner you have NO history as to what was done. SO everything needs checking, pressure cap? correct. Belts see the notes from training, fan direction, if it can be done wrong it will.
As a last last tst I would remove thermostat seeing if system remains cool.
jtec is offline
