2006 Grand Cherokee Laredo Lift question - JeepForum.com
 1Likes
  • 1 Post By rockawaywk
post #1 of 11 Old 07-22-2020, 12:51 PM Thread Starter
Mcee278
Hey all , planning on buying a lift kit this weekend but I have a few questions . I plan on getting a 2” kit or a 2.5” kit. My questions are : Is there a noticeable difference when looking at the two of them lifted? Can you see and when sitting inside the Jeep feel that the Jeep is lifted with the both? Also not looking to spend a ton but can you give me some good brands to look at? I am also looking to buy front and back struts and springs , in total spending about 600.00 if possible. One last question gonna need some new tires once lifted , what size can go with , without putting spacers and no rubbbing at all. Thanks in advance all!!!
Mcee278 is offline
post #2 of 11 Old 07-22-2020, 08:49 PM
rockawaywk
2006 WK
Welcome!!
I have an 06 Laredo as well and put on a new lift in the last 6 months. @Kolak is a vendor here that will get you the best prices and has the most knowledge regarding lifts for our trucks. I went with OME MD springs and Bilstein 4600 fronts and 5125 rears and I couldn't be happier. Kolak showed me my options and gave me all the information I needed to make a choice. Lift is roughly 2.5" and is very noticeable with new tires. Before this I had the Rough Country 2" lift and didn't like the look or feel of the ride.
I'm not sure if you can fit bigger tires without spacers but I'm running 265/70-17 with 1.25" spacers and its exactly what I wanted.
Kolak likes this.
rockawaywk is offline
post #3 of 11 Old 07-22-2020, 08:56 PM Thread Starter
Mcee278
Thanks for the info Rockaway.
Mcee278 is offline
post #4 of 11 Old 07-30-2020, 07:48 PM Thread Starter
Mcee278
Anyone else with some insight ???
Mcee278 is offline
post #5 of 11 Old 07-30-2020, 08:36 PM
SteveROntario
The WK isn't like a truck with a flat hood so you won't feel like it is lifted when sitting inside of it. Sitting in a WK is more like sitting in a car in my opinion.
You will want to inspect your suspension before ordering a lift as you may need to replace wear items at the same time.
I have the Bilstein 5100's with 2" lift up front and 2" spacers in the back. This is fine for ripping on the highway and the occasional offroading. It's really stable with the stock springs but the rears do sag a lot when fully loaded.
I did a 5" lift on my Chevy Express 3500 about a month ago and you can really tell its lifted in the fact that the seat is 5" higher off the ground. 2" wouldn't be noticeable in it either.
2013 Civic, 2009 Suzuki DRZ-400SM, 2008.5 Grand Cherokee CRD, 1991 Dodge B250, 1934 Hupmobile 417W
SteveROntario is online now
post #6 of 11 Old 07-30-2020, 09:18 PM Thread Starter
Mcee278
Thanks for answering. So I think I am going to go with a 2.5 inch lift. Now what kit would you recommend for a 2.5 inch lift? I will also need new shocks and struts all around
Mcee278 is offline
post #7 of 11 Old 07-31-2020, 04:36 AM
WKjeepster
I would contact Kolak as stated above, he will give you the best deal and insight on what you need......
WKjeepster is offline
post #8 of 11 Old 07-31-2020, 09:19 PM Thread Starter
Mcee278
Yes I have been talking to @Kolak through pm but for some reason it won’t let me pm anymore
Mcee278 is offline
post #9 of 11 Old 08-01-2020, 07:06 AM Thread Starter
Mcee278
Does anyone have an email for @Kolak
Mcee278 is offline
post #10 of 11 Old 08-01-2020, 02:08 PM
Kolak
Vendor
Kolak's Avatar
You can reach me at [email protected]
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #11 of 11 Old 08-04-2020, 10:45 PM
kbwk
2008 WK
I have OME MD in the front and HD in the back, perfect for me. I run 5100’s in the front/rear.. ended up spending way more money than I’d hoped for tinkering. If you’re looking for 2.5” of lift then I’d second going with OME MD and the 4600s. The 4600s have the same valving as the 5100 IIUC, and I really like the feel of those with the MD springs. I regret not going with a longer shock I the rear, like the 5125 / OME / King.
kbwk is offline
