2006 Grand Cherokee 4.7 P0339 & P0300 core - JeepForum.com
post #1 of 8 Old 05-24-2019, 10:41 PM Thread Starter
904block
So the other day I was home . And out of no where my check engine came on when I was at the red light so I didn't think was urgent so I had planned to wait when I got home . So when I started to accelerate my Jeep started buckling or Stumbling hard so I pulled into a gas station Read the code P0339 so I disconnected the battery for 10 seconds and the check engine light didn't come back on, but since the Crank sensor was from Autozone I decided to replace it. So when I installed the new sensor and started my Jeep the RPM's started jumping and it seemed like the Jeep wanted to stall out. So I shut the Jeep off disconnected the battery installed the warranty sensor for another new one and same results . But now with the P0300 code
So this is what I Ruled out
(1)The battery and Starter the Jeep turns over no problem
(2) The Cam Position Sensor I replaced it last summer
(3) Throttle Position Sensor recently replace
(4) Ignition Coils less than a month old
(5) Crank Sensor I replaced it with three new sensor at AutoZone
Sorry I'm making this longer than it should be I'm trying to gave more details . But iam going to the junkyard tomorrow to remove a Crank sensor and wire Harness from another Jeep just in case the wire is burnt since there on back order at the dealership
904block is offline
post #2 of 8 Old 05-24-2019, 10:49 PM Thread Starter
904block
And by the way I do my oil changes every 5k and spark plugs , Air filter , every 10-15k
904block is offline
post #3 of 8 Old 05-25-2019, 11:28 AM Thread Starter
904block
Update so I went to the Junkyard and pull a Crank sensor out a different Jeep and guess what? All my problems went away stay away from Autozone for some parts
904block is offline
post #4 of 8 Old 05-25-2019, 01:53 PM
RCS1300
2005 WK
Autozone is not the problem. Jeeps like only OEM sensors.
RCS1300 is offline
post #5 of 8 Old 05-27-2019, 09:33 AM
YJ325i
2007 XK Commander
In AZ defense, I had a WK 4.7L once that has sync codes. Got a crk/cam set from dealer. Same codes, almost started checking the chain, on a whim got a set from AZ. Fixed. Sometimes itís just the luck of the batch. Also, maybe the connector was the real fix🤔
95 YJ 2.5L 33" BFG mt's 8.8 sye 4Ē lift
94 ZJ 4.0L 97 TJ Sahara
Past: 95 & 96 XJís 04 Liberty
YJ325i is offline
post #6 of 8 Old 05-28-2019, 10:21 AM Thread Starter
904block
Maybe it was that particular Sensor from AZ didn't work because I tried three different sensors from AZ of the same Part number and it wasn't working but I believe the AZ sensor had a different Ohm than the dealership sensor
904block is offline
post #7 of 8 Old 05-28-2019, 10:22 AM Thread Starter
904block
But I never changed the connector I just put in a sensor from the dealer and the problems went away
904block is offline
post #8 of 8 Old 05-28-2019, 02:46 PM
2005JGC
2005JGC's Avatar
2005 WK
I stay away from aftermarket sensors for Chrysler as much as possible! Even if it works out the gate, they never last as long in my experience. Dealt with 1 too many customers pissed off that their PT Cruiser was just towed in because it needs a new camshaft position sensor when they just paid a shop 6 months ago to replace it. There is not really any aftermarket brand that I would stand behind on a Chrysler product, every. single. one. would be sold with the "this may not last very long" caveat.
2005 Jeep Grand Cherokee - Work in progress...
2005JGC is offline
WJ 4.7 Alternator replacement & upgrade write-up Uniblurb WJ Grand Cherokee Forum 27 05-20-2019 01:23 PM
08 4.7 Gr Cherokee P0300 Megalodon47 Engines & Drivetrain 5 03-22-2019 10:08 PM
2006 Commander 4.7 CommanderBebop Commander 0 12-23-2018 09:56 AM
Overheated 4.7 2006 XK - Blown head gasket? caveman69 WK Grand Cherokee & XK Commander Forum 2 12-08-2018 04:48 AM
2006 4.7 Misfire wesilva WK Grand Cherokee & XK Commander Forum 2 09-12-2018 08:28 PM
