2005 Headlight Adjustments UP Down Vertical - JeepForum.com
post #1 of 8 Old 09-13-2015, 11:49 AM Thread Starter
lionfish37
I cant for the life of me find on how to adjust up down on the headlights driver side is up to high and got pulled over last night. I found the left right adjustment and googles the heck out of Vertical.
Any Help Guys?
Thanks
lionfish37 is offline
post #2 of 8 Old 09-13-2015, 02:03 PM
SilverLimited
2019 WK
My 2005 is not home right now, but I'm also certain its at location #1 on the diagram below. Might need a small hex socket to turn it. The early model year WK's starting at 2005 had that cover noted as #2 on the diagram that can be removed for easier access. New models had that cover deleted.
15 WK2 Overland 3.6L QTII
05 WK Limited 5.7L QDII
01 WJ Limited 4.7L QuadraDrive
00 WJ Laredo-gone
SilverLimited is offline
post #3 of 8 Old 09-13-2015, 02:08 PM Thread Starter
lionfish37
OK I am going to check now I see the Hex one that is L and Right, going to get to the bottom of this, thanks for your help.
post #4 of 8 Old 09-13-2015, 02:11 PM
chance_p
2008 WK
L and R is lower and raise. I think I read about that causing some confusion before in regards to headlight adjustment on our WKs
08 WK 4.7 QTII - 4" Superlift - JK Moabs - 265/70 Cooper AT/3 - Flashpaq
chance_p is offline
post #5 of 8 Old 09-13-2015, 02:49 PM Thread Starter
lionfish37
Well thanks for that and you win the prize for sure Chance_P that is correct thanks a ton going to get them dialed in tonight.
Again Thanks
post #6 of 8 Old 09-14-2015, 05:47 AM
Moparknighthawk
2006 WK
Most cars do not have left and right adjustment anymore. My 2006 Daytona and my 06 Grand Cherokee only have up and down. In fact, even my 2013 Focus only has up and down adjustment.
Greg
2006 Silver Grand Cherokee Laredo "Country"
Moparknighthawk is offline
post #7 of 8 Old 09-14-2015, 10:31 AM
chance_p
2008 WK
Another little tip, if you're adjuster doesn't work, you can try tightening it all the way down. You may be able to re seat the adjuster and bring it back to life. You'll hear a loud pop if it goes back into place.
chance_p is offline
post #8 of 8 Old 03-28-2020, 02:56 PM
Sunnygirl64
Chance_p thank you! Lower rise, of course!
Sunnygirl64 is offline
