JeepForum.com (https://www.jeepforum.com/forum/)
-   WK Grand Cherokee & XK Commander Forum (https://www.jeepforum.com/forum/f67/)
-   -   2005 Headlight Adjustments UP Down Vertical (https://www.jeepforum.com/forum/f67/2005-headlight-adjustments-up-down-vertical-3404866/)
lionfish37 09-13-2015 11:49 AM
I cant for the life of me find on how to adjust up down on the headlights driver side is up to high and got pulled over last night. I found the left right adjustment and googles the heck out of Vertical.
Any Help Guys?
Thanks
SilverLimited 09-13-2015 02:03 PM
1 Attachment(s)
My 2005 is not home right now, but I'm also certain its at location #1 on the diagram below. Might need a small hex socket to turn it. The early model year WK's starting at 2005 had that cover noted as #2 on the diagram that can be removed for easier access. New models had that cover deleted.
lionfish37 09-13-2015 02:08 PM
OK I am going to check now I see the Hex one that is L and Right, going to get to the bottom of this, thanks for your help.
chance_p 09-13-2015 02:11 PM
L and R is lower and raise. I think I read about that causing some confusion before in regards to headlight adjustment on our WKs
lionfish37 09-13-2015 02:49 PM
Well thanks for that and you win the prize for sure Chance_P that is correct thanks a ton going to get them dialed in tonight.
Again Thanks
Moparknighthawk 09-14-2015 05:47 AM
Most cars do not have left and right adjustment anymore. My 2006 Daytona and my 06 Grand Cherokee only have up and down. In fact, even my 2013 Focus only has up and down adjustment.
chance_p 09-14-2015 10:31 AM
Another little tip, if you're adjuster doesn't work, you can try tightening it all the way down. You may be able to re seat the adjuster and bring it back to life. You'll hear a loud pop if it goes back into place.
Sunnygirl64 03-28-2020 02:56 PM
Chance_p thank you! Lower rise, of course!
The time now is 11:44 PM.
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
