JeepForum.com (https://www.jeepforum.com/forum/)
-   WK Grand Cherokee & XK Commander Forum (https://www.jeepforum.com/forum/f67/)
-   -   2005 Grand Cherokee: Blend air door problem (https://www.jeepforum.com/forum/f67/2005-grand-cherokee-blend-air-door-problem-4371455/)
Runforit97 09-17-2019 12:18 PM
I recently replaced my blend door actuator due to ratcheting sounds from inside the passenger side dash area, which turned out to be the small plastic sprockets slipping on each other. These sprockets drive the blend door open and closed. I opened the old actuator and discovered it was damaged inside so I replaced it. After it was replaced the ratcheting stopped...for 2 days. However, today the sound came back. Does anyone know if I purchased a faulty actuator or is there a deeper problem that is causing the actuator to fail? Any help is greatly appreciated.
IlanLCD 09-17-2019 03:30 PM
Read here:
https://www.jeepforum.com/forum/f67/...gears-3381362/
If that is your problem, I am running another manufacturing batch of the black small part
Runforit97 09-18-2019 12:00 PM
Originally Posted by IlanLCD (Post 40742749)
Read here:
https://www.jeepforum.com/forum/f67/n...gears-3381362/
Those plastic sprockets are actually intact and in really good condition it currently is working properly at the moment but seems to go in-and-out of proper operation. From what I can tell the actuator itself does not know when to stop running which then causes one of the gears inside the actuator to break because the recirc blend door is shut but the sprocket that drives it puts too much torque on 1 of the small gears in the actuator and it snaps
The time now is 05:52 PM.
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
