12v power for rear accessories - JeepForum.com
 2Likes
  • 1 Post By BadExample
  • 1 Post By SteveROntario
post #1 of 8 Old 07-14-2019, 10:32 PM Thread Starter
jeeptorino68
1992 XJ Cherokee
Whats the best place to get 12 volts at the back of the jeep for some accessories,
Rear roof rack lights, and rear locker
I have switches at the dash, abd relays I would mount somewhere...but best spot for power is? 12 volt socket in the cargo area?
Kyle
92 XJ 4.0 HO,AW4, NP242, 30" BFG AT, 1.75 spacer and ZJ coils, double cherokee leaf pack and 2 inch rough country shackles, 2.5 inch dnynomax exhaust, magnaflow cat, front hooks & rear hitch, gas skid, front skid, warn t-case skid, 99+ intake, bored TB
02 KJ Limited, 255 70 16s, front skid, LS/373 gears
jeeptorino68 is offline
post #2 of 8 Old 07-15-2019, 03:30 AM
BadExample
BadExample's Avatar
2006 WK
That's probably your best bet. Otherwise you probably need to run a wire from the front. I'm not sure if that's powered on with the key off though.
badgerwithhands likes this.
CJ5 we don't talk about, 58 Willys CJ-3B gone
79 J-10 gone, 99 GC WJ murdered and gone
2006 GC WK
BadExample is offline
post #3 of 8 Old 07-15-2019, 04:54 AM
caulk04
2008 WK
If you have the 7-pin trailer harness, there is a live 12v pin in it. FYI.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #4 of 8 Old 07-15-2019, 07:03 AM Thread Starter
jeeptorino68
1992 XJ Cherokee
I dont have the 7 pin factory harness.
Thanks for the tips
Kyle
post #5 of 8 Old 07-15-2019, 05:28 PM
SteveROntario
I thought there was a socket in the cargo area. Left side? You can easily run some duplex wire along the inside of the jeep under the sill plates. You can pop them out and also tuck the wire under the remainder of the trim.
2013 Civic, 2009 Suzuki DRZ-400SM, 2008.5 Grand Cherokee CRD, 1991 Dodge B250, 1934 Hupmobile 417W
SteveROntario is offline
post #6 of 8 Old 07-17-2019, 01:51 PM
underscore
2007 WK
The socket in the trunk is always live, at least mine is. If you need it switched there might be something in the wiring for the amp that's right beside it that you could use to trigger a relay.
07 WK CRD//QDII//OME MD//OMG WTF BBQ [daily]
91 Celica GTFour RC [for sale]
underscore is offline
post #7 of 8 Old 07-18-2019, 08:13 PM
MarcosLlamas
2008 WK
I have a 12v socket
Sent from my LM-Q710(FGN) using Tapatalk
MarcosLlamas is offline
post #8 of 8 Old 07-18-2019, 08:15 PM
MarcosLlamas
2008 WK
Here
