08 wk 3.0l rack and pinion help. - JeepForum.com
post #1 of 3 Old 09-15-2021, 10:33 AM Thread Starter
Pl30n4sm
I need some help, my rack and pinion is leaking, leaks getting worse by the week and i will definitely need to replace it soon. Im looking for some input from other wk owners.
1. Can our wk rack and pinion be rebuilt? Would it be worth rebuilding?
2. Anyone have any upgraded rack and pinion system worth buying over stock/oem? I'm running a 2" lift with upgraded upper control arms and spacers to run 33" tires. I've always believed in putting in stronger parts when the originals fail.
3. If there isn't an upgraded rack and pinion system worth buying do any of you have any negative comments about the Cardon' brand over mopar? I've seen two options from rockauto. A cardone oem and mopar. Any reason for the large gap in price range ? The reman mopar is listed at $858.24 + $95.11 core charge vs a new cardone listed at $628.71 or a reman cardone listed at $245.75 + a $133.15 core charge.
Does anyone have any other options ?
I am living in northern Alberta Canada, all prices are listed in Canadian.
Pl30n4sm is offline
post #2 of 3 Old 09-19-2021, 07:39 PM
Roadcracks
Roadcracks's Avatar
2008 WK
Did you ever get this solved? I've had good service from Cardone but not 100%. Usually bought rebuilt calipers.
Happiness makes up in height what it lacks in length. Robert Frost American Poet.
Roadcracks is offline
post #3 of 3 Old 09-21-2021, 05:52 PM
Raffish
2005 WK
I just put in a reman cardone, all good so far, about 2 months...
And hi from Calgary!!
05 WK Limited 5.7, QDII, OME HD, 265/70/17 1.25" Spydertrax, CC, MBRP SS, 250xxxkms
Raffish is offline
