08 crd getting poorer fuel economy - JeepForum.com
post #1 of 9 Old 09-18-2019, 07:03 AM Thread Starter
02zedr2
Morning, sorry if this has been answered already tried searching and couldn't come up with anything.
I have a 2008 wk crd with 230 000km(140 000 miles) on it. I used to get around 20-22 mpg but lately I've been getting 17-18 doing the same route I've always done. I've checked the basic stuff, air filter, tires inflated properly, alignment. No codes come up, and it drives great, just wondering what's some other stuff I can look at
Thanks
02zedr2 is offline
post #2 of 9 Old 09-18-2019, 10:56 AM
Xmind
2007 WK
How long have you owned the vehicle? Do you drive mostly short distances each day and do you have the DPF yet? It could be the regen on the DPF is trying to run, but can't complete if you have too short of drives.
It shouldn't affect it by that much, but worth the 5 minutes to remove the engine cover and foam blocks to check the injectors to ensure none are leaking, nor the fuel filter.
'07 GC CRD QDII
Xmind is offline
post #3 of 9 Old 09-18-2019, 01:18 PM Thread Starter
02zedr2
Owned it for the last 70 000kms, most of my drives are 30+ min, don't have the cover on and didn't see anything that jumps out at me that looks like it's leaking.
02zedr2 is offline
post #4 of 9 Old 09-18-2019, 02:35 PM
terrasmak
2007 WK
Ambient temp, mine gets 2 mpg less in the summer
"Racing makes Heroin addiction look like a vague wish for something salty." -- Peter Egan
terrasmak is offline
post #5 of 9 Old 09-20-2019, 12:34 AM
rokrau
2008 WK
Small leaks in the intercooler and related plumbing will cause diminished fuel efficiency. Maybe do a visual inspection of the pipe coming from the turbo, the resonator and its connections to the intercooler then on the other side the hose going to the throttle body.
If it’s leaking there will be black soot (assuming there never was a modification to the PCV valve routing aka Elephanf Hose Mod).
Best of luck.
--Roland, 2008 Grand Cherokee Overland, 3.0 CRD, EHM and TRD
rokrau is online now
post #6 of 9 Old 09-20-2019, 08:06 PM
ZJPunk98
ZJPunk98's Avatar
2007 WK
Clogged DPF (as noted above), EGR valve stuck open, leaking fuel injectors, bad fuel filter (maybe), leaks in intake or boost loss maybe.
Erik
98ZJ sold, 02WJ sold, 07 WK CRD
ZJPunk98 is offline
post #7 of 9 Old 09-21-2019, 05:07 AM
browningv308
Mine used to get 22 average, I took the front air dam { or whatever it's called } off and mpg went to 19 average, then I added a 2'' lift and 265's now the mpg says 18 I know the computer is off with the taller tires. But is it possible your computer is off, have you tried to do the math yourself?
browningv308 is offline
post #8 of 9 Old 09-21-2019, 09:25 AM Thread Starter
02zedr2
Thanks all for your replies, I'll look to see if I can find some leaks in the pipe, it's very possible, I never did the elephant hose mode so it's still factory, I had the intercooler replaced a couple weeks back since some lady backed into the jeep and pushed one of the bolts through the intercooler. Is there a way to tell if the dpf is clogged?
02zedr2 is offline
post #9 of 9 Old 09-24-2019, 12:55 PM
ggrassmid
2008 WK
Could be time of year... some place start switching over to winter blended fuel which can have a negative affect on fuel mileage.
Check air filter
Check fuel filter
ggrassmid is offline
