JeepForum.com (https://www.jeepforum.com/forum/)
-   WK Grand Cherokee & XK Commander Forum (https://www.jeepforum.com/forum/f67/)
-   -   08 crd getting poorer fuel economy (https://www.jeepforum.com/forum/f67/08-crd-getting-poorer-fuel-economy-4371553/)
02zedr2 09-18-2019 07:03 AM
Morning, sorry if this has been answered already tried searching and couldn't come up with anything.
I have a 2008 wk crd with 230 000km(140 000 miles) on it. I used to get around 20-22 mpg but lately I've been getting 17-18 doing the same route I've always done. I've checked the basic stuff, air filter, tires inflated properly, alignment. No codes come up, and it drives great, just wondering what's some other stuff I can look at
Thanks
Xmind 09-18-2019 10:56 AM
How long have you owned the vehicle? Do you drive mostly short distances each day and do you have the DPF yet? It could be the regen on the DPF is trying to run, but can't complete if you have too short of drives.
It shouldn't affect it by that much, but worth the 5 minutes to remove the engine cover and foam blocks to check the injectors to ensure none are leaking, nor the fuel filter.
02zedr2 09-18-2019 01:18 PM
Owned it for the last 70 000kms, most of my drives are 30+ min, don't have the cover on and didn't see anything that jumps out at me that looks like it's leaking.
terrasmak 09-18-2019 02:35 PM
Ambient temp, mine gets 2 mpg less in the summer
rokrau 09-20-2019 12:34 AM
Small leaks in the intercooler and related plumbing will cause diminished fuel efficiency. Maybe do a visual inspection of the pipe coming from the turbo, the resonator and its connections to the intercooler then on the other side the hose going to the throttle body.
If it’s leaking there will be black soot (assuming there never was a modification to the PCV valve routing aka Elephanf Hose Mod).
Best of luck.
ZJPunk98 09-20-2019 08:06 PM
Clogged DPF (as noted above), EGR valve stuck open, leaking fuel injectors, bad fuel filter (maybe), leaks in intake or boost loss maybe.
browningv308 09-21-2019 05:07 AM
Mine used to get 22 average, I took the front air dam { or whatever it's called } off and mpg went to 19 average, then I added a 2'' lift and 265's now the mpg says 18 I know the computer is off with the taller tires. But is it possible your computer is off, have you tried to do the math yourself?
02zedr2 09-21-2019 09:25 AM
Thanks all for your replies, I'll look to see if I can find some leaks in the pipe, it's very possible, I never did the elephant hose mode so it's still factory, I had the intercooler replaced a couple weeks back since some lady backed into the jeep and pushed one of the bolts through the intercooler. Is there a way to tell if the dpf is clogged?
ggrassmid 09-24-2019 12:55 PM
Could be time of year... some place start switching over to winter blended fuel which can have a negative affect on fuel mileage.
Check air filter
Check fuel filter
The time now is 07:40 AM.
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
