06 Commander 4.7L drivetrain noise! - JeepForum.com
post #1 of 7 Old 05-21-2019, 10:15 PM Thread Starter
Maverickxeo
Maverickxeo's Avatar
My dad bought an 06 Commander and has replaced a few parts (needed to be done): front and rear wheel bearings, changed all fluids aside from transfer case (NP245) and transmission, front upper/lower control arms, front axleshafts, and front driveshaft CV joint.
There is a noise though that we cannot figure out. When driving, it can be heard both by accelerating and decelerating (to a point, that is). It cannot be heard OUTSIDE of the vehicle (I had my head hanging out every window, haha!) but only inside with the windows up (it can be heard with the windows down, but it 'matches' the wind noise, if that makes sense).
The noise itself sounds like a woosh woosh woosh noise... almost a grinding noise but not quite.
Any ideas where to start to look for that one?
Maverickxeo is offline
post #2 of 7 Old 05-22-2019, 07:36 AM
yzjwk
yzjwk's Avatar
2005 WK
Other then driving the vehicle on blocks and listening or spinning by hand..
-Alignment done after changing the LCAs ?
- QDII ? mopar friction modifier added to the diffs?
- check rear brakes for delaminated drum parking brakes inside the rotor hats. (hard to hear from the front of the vehicle)
- TC fluid level ok ?
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #3 of 7 Old 05-23-2019, 03:21 AM Thread Starter
Maverickxeo
The noise sounds like its coming from the rear. I forgot to say that we did change all the brakes and rotors as well. Did not change parking brakes though. TC fluid looked okay and was full. No friction modifier added as we did both the 'wheel spin test' and checked the VIN which showed open diffs. No alignment done yet.
post #4 of 7 Old 05-23-2019, 08:49 AM
yzjwk
yzjwk's Avatar
2005 WK
The parking brake shoes are a well known problem with these and the lack or improper adjustment as well.
I know on the ZJ a bad rear outer axle bushing will make that kind noise but I don't think the WK has those. Bushings are in the pumpkin on these I believe.
90 YJ Islander 4.2L
2010 MK Patriot
yzjwk is offline
post #5 of 7 Old 06-06-2019, 03:06 PM
19thejeepguy91
I was wondering if anyone could help me figure out my engine noise
19thejeepguy91 is offline
post #6 of 7 Old 06-06-2019, 06:26 PM
BadExample
BadExample's Avatar
2006 WK
Start a thread with your best description of all symptoms as well as details of year, engine and options. Someone will help.
CJ5 we don't talk about, 58 Willys CJ-3B gone
79 J-10 gone, 99 GC WJ murdered and gone
2006 GC WK
BadExample is online now
post #7 of 7 Old 06-07-2019, 03:13 PM
Walt
2008 WK
... 06 Commander ....The noise itself sounds like a woosh woosh woosh noise... almost a grinding noise but not quite....Any ideas where to start to look for that one?
...and check that the emergency brake cable is not rubbing on the driveshaft. Hope it is that simple.
HEMI CLUB MEMBER #45; SILVER WK CLUB MEMBER #13
'08 WK GC Limited. 5.7L HEMI. Quadra-Trac II. Bright Silver Metallic. Class IV hitch.
Michelin LTX M/S tires. Fumoto oil drain valve. Billet Technology oil catch can.
Walt is online now
1992 YJ Drivetrain Noise specks5149 YJ Wrangler Technical Forum 4 03-26-2019 05:40 PM
Dana 35 troubles. Need advice! A9000 ZJ Grand Cherokee Forum 6 11-27-2018 09:07 PM
Chattering Drivetrain Noise dynosaur100 YJ Wrangler Technical Forum 27 10-21-2018 10:33 AM
Need Sherlock Homes for this one....suspension noise on WK MacJeepWk WK Grand Cherokee & XK Commander Forum 9 05-26-2018 07:11 PM
Drivetrain noise ElianM Engines & Drivetrain 6 01-22-2018 11:22 AM
