05 wk gas skid rusted - JeepForum.com
 2Likes
  • 2 Post By Walt
post #1 of 12 Old 04-11-2019, 11:30 AM Thread Starter
05WKwhite
2005 WK
My gas tank skid is completely rusted out in the center exposing the plastic tank.
How vulnerable is the tank? Or should I even be worried about it at all?
Thanks all
05WKwhite is offline
post #2 of 12 Old 04-11-2019, 02:24 PM
BadExample
BadExample's Avatar
2006 WK
Thanks all
Isn’t that what holds it in?
CJ5 we don't talk about, 58 Willys CJ-3B gone
79 J-10 gone, 99 GC WJ murdered and gone
2006 GC WK
BadExample is offline
post #3 of 12 Old 04-12-2019, 12:02 AM Thread Starter
05WKwhite
2005 WK
[/QUOTE]
Isn’t that what holds it in?[/QUOTE]
Good point lol I don’t know. I was worried about the plastic being soft but now I’ll have to look at what you said. It’s just the center for now but it won’t be long before the sides fail.
Thanks for the input
post #4 of 12 Old 04-12-2019, 06:37 AM
jeeptorino68
1992 XJ Cherokee
Yes, the skid plate, either the metal guard or the true skid plate, is all that holds the tank up. I would start searching out a replacement.
Kyle
92 XJ 4.0 HO,AW4, NP242, 30" BFG AT, 1.75 spacer and ZJ coils, double cherokee leaf pack and 2 inch rough country shackles, 2.5 inch dnynomax exhaust, magnaflow cat, front hooks & rear hitch, gas skid, front skid, warn t-case skid, 99+ intake, bored TB
02 KJ Limited, 255 70 16s, front skid, LS/373 gears
jeeptorino68 is offline
post #5 of 12 Old 04-12-2019, 08:33 AM
RCS1300
2005 WK
I have an 05 and replaced mine last year. Take the opportunity to replace the fuel pump also, if you have not already.
RCS1300 is offline
post #6 of 12 Old 04-12-2019, 12:04 PM Thread Starter
05WKwhite
2005 WK
Ok on the fuel pump. Haven’t done it yet.
As far as the skid goes I have the full skid. Should I look for stock replacement or aftermarket since I have to get another anyway??
Thanks again for all the help
post #7 of 12 Old 04-12-2019, 12:06 PM
BadExample
BadExample's Avatar
2006 WK
I don't have the skid on mine, so it has an almost skid plate, more of a frame. If you don't need it as a skid plate, PITA, but you could drop it, cut out the deep and through rust, wire rush the surface rust and rustolium the snot out of it.
If you do want the protection back, maybe weld or rivet on a 3/16" plate over the hole... or aftermarket. OEM is over $250 IIRC and a thicker aftermarket wouldn't be much more. Just make sure whatever faces up is smooth, so it wound abrade the plastic.
2006 GC WK
post #8 of 12 Old 04-12-2019, 01:44 PM
RCS1300
2005 WK
My skid plate was purchased on Amazon from Mopar in 2017. It cost me $282 at the time. When I took it off I learned that there was no way possible to repair or reuse it. Sold it for scrap metal and got a few $$.
RCS1300 is offline
post #9 of 12 Old 04-12-2019, 04:16 PM
BadExample
BadExample's Avatar
2006 WK
Ha! Got under mine to look at some stuff and realized I do have the gas skid on there. Dull black looks like plastic. I cracked me up. I thought the straps were holding it on.
2006 GC WK
post #10 of 12 Old 04-12-2019, 06:04 PM
Walt
2008 WK
Jeep gets a second person........I thought the front plastic cover was a skid plate until I changed oil for the first time.
VA_57WK and BadExample like this.
HEMI CLUB MEMBER #45; SILVER WK CLUB MEMBER #13
'08 WK GC Limited. 5.7L HEMI. Quadra-Trac II. Bright Silver Metallic. Class IV hitch.
Michelin LTX M/S tires. Fumoto oil drain valve. Billet Technology oil catch can.
Walt is offline
post #11 of 12 Old 04-12-2019, 09:29 PM
BadExample
BadExample's Avatar
2006 WK
LOL I have the same POS on mine. Replacement in el garaha. I'll bet I can get it to skip a few times on a storage pond.
How about that weird ast rear suspension frame thingy? Is it active, passive, good, bad or ugly?
2006 GC WK
post #12 of 12 Old 04-14-2019, 10:17 AM Thread Starter
05WKwhite
2005 WK
Who makes good aftermarket skids for the fuel tank? I’ve only found one but I’d like more options if there are any?
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3853 02-12-2019 09:15 AM
Gas Tank Skid Plate Removal Install Help splouie WJ Grand Cherokee Forum 3 01-04-2019 11:45 AM
Gas tank skid plate ton12loc YJ Wrangler Technical Forum 5 06-28-2018 12:55 PM
Gas tank skid vs Fuel cell Turtle_XJ TJ Wrangler Technical Forum 29 04-13-2018 08:30 PM
skid row gas tank skid willis36 WJ Grand Cherokee Forum 9 12-21-2017 05:28 PM
