05 WK fog light wiring question - JeepForum.com
post #1 of 5 Old 01-15-2020, 11:40 AM Thread Starter
05WKwhite
2005 WK
Is it possible to wire the factory fogs in such a way that when I upgrade them to 75wats aftermarket units, I can still use the factory switch but use better wiring?
05WKwhite is offline
post #2 of 5 Old 01-15-2020, 12:23 PM
Rtbrjason
Rtbrjason's Avatar
2008 WK
You can do this with a relay and your own larger gauge wires. They also sell kits for this. They were often used for after market HID kits, where you wanted to run the lights from the battery while still using the factory switch.
Innovited Universal relay wiring harness for all HID single kit H1, H3, H4, H7, H8, H9, H10, H11, H13, 9004, 9005, 9006, 9007, 5202, 880, 884 https://www.amazon.com/dp/B00XKK74Y2..._RH1hEbHH45PQ7
Rtbrjason is offline
post #3 of 5 Old 01-15-2020, 10:11 PM Thread Starter
05WKwhite
2005 WK
So this is plug and play type harness? I don’t mind running the harness if it’s really
That easy lol
post #4 of 5 Old 01-17-2020, 10:26 PM
wcjeep01
Running your own relay to power a bigger draw is not difficult. Your current switch becomes the trigger for the relay. The relay then supplies power to the new lights. This lowers the demand on the OEM switch.
wcjeep01 is offline
post #5 of 5 Old 01-20-2020, 03:21 PM Thread Starter
05WKwhite
2005 WK
Great! Could you point me to a write up on how to do it or walk me through it ?
Please and thanks lol
