05 Jeep GC 3.7 tranny issues or wiring. - JeepForum.com
 1Likes
post #1 of 17 Old 03-07-2019, 06:33 AM Thread Starter
Onbeat1
Hello guys, I got a 2005 Jeep grand Cherokee 3.7 L with 220,000 miles. For the past couple months it has been stuck in third gear and I’ve noticed I can shift it without pushing my brake pedal in and I change my brake light sensor. The last time I had a code checked it was saying something about a stuck A solenoid. And I’ve also changed the transmission speed sensor several times and nothing has worked I change the fluid and nothing I’m at a loss and stuck between a bad wiring issue or bad solenoids. Any help would be appreciated thank you
Onbeat1 is offline
post #2 of 17 Old 03-07-2019, 07:21 AM
jtec
2014 JK Wrangler
Step 1 -
Use a scanner to access ALL codes, post them here someone will advise how to proceed.
jtec is offline
post #3 of 17 Old 03-08-2019, 12:49 PM Thread Starter
Onbeat1
I did.. it said I had a stuck A solenoid
Onbeat1 is offline
post #4 of 17 Old 03-08-2019, 02:17 PM
jtec
2014 JK Wrangler
could you SHARE the codes?
jtec is offline
post #5 of 17 Old 03-09-2019, 05:48 AM
Nejeep
Try cleaning or changing the solenoids and conductor plate inside the valve body. Since this trans is used in lots of vehicles there are several Youtube videos on this process. Here is one:
19 Limited 4x4 3.6 White/Tan new daily driver
06 Laredo for 11 years
97 Laredo for 14 years
Nejeep is offline
post #6 of 17 Old 03-09-2019, 06:33 PM Thread Starter
Onbeat1
Here are my error codes as of right now.
P0752 - shift solenoid A stuck on.
P0753 - shift solenoid A electrical.
Onbeat1 is offline
post #7 of 17 Old 03-10-2019, 09:23 AM
jtec
2014 JK Wrangler
can you confirm this is a NAG1 trans- we are assuming* so checking is advised.
p0753 is a circuit issue I would start there
*based on spec sheets
jtec is offline
post #8 of 17 Old 03-10-2019, 07:34 PM Thread Starter
Onbeat1
Yes, I already confirmed this with the dealer and I’ve already swapped out the speed sensor 4 times (the conductor plate) 3 of which were used. Two worked for a rough 2-3 months then quit. So I bought the 4th and final one from AutoZone for 260$ It didn’t even attempt to work. That threw me off by a mile. Which brings me here.
Onbeat1 is offline
post #9 of 17 Old 03-11-2019, 06:38 AM
Nejeep
I would recommend carefully inspecting the transmission wiring and connectors for damage or corrosion. The wiring diagram provided by jtec should be helpful.
Do the transmission solenoids check out for resistance (ohms) and move when energized with 12 volts? I have seen the resistance specs somewhere so you should be able to search for them.
Edit: The resistance specs are included on the jtec diagram.
Nejeep is offline
post #10 of 17 Old 03-12-2019, 08:36 AM Thread Starter
Onbeat1
Okay, I’m going to be doing my solenoid checks friday as the weather warms up.
Onbeat1 is offline
post #11 of 17 Old 03-12-2019, 08:59 AM
2005JGC
2005JGC's Avatar
2005 WK
FWIW, the 3.7l ONLY came paired with the NAG1 transmission.
2005 Jeep Grand Cherokee - Work in progress...
2005JGC is offline
post #12 of 17 Old 03-12-2019, 09:06 AM
jtec
2014 JK Wrangler
that is what the specs say, a confirmation is always suggested- gone down the wrong rabbit whole and learned. *** U ME
jtec is offline
post #13 of 17 Old 03-30-2019, 11:18 AM Thread Starter
Onbeat1
Help fellas, changed my Speed sensor and still nothing good. Changed the solenoids and still the Jeep is in limp mode. I’m literally lost as to what this thing issue is.
Onbeat1 is offline
post #14 of 17 Old 03-30-2019, 12:34 PM
jtec
2014 JK Wrangler
WHY are you spending money?
Did you even read the attachment I added - do any of the tests?
Is it above comfort level to check wiring?
T1m likes this.
jtec is offline
post #15 of 17 Old 03-31-2019, 11:29 AM Thread Starter
Onbeat1
WHY are you spending money? <img src="https://www.jeepforum.com/ubb/confused.gif" border="0" alt="" title="Confused" class="inlineimg" />
I’ve had this part for a little while. The weather hasn’t permitted changing this part. I’m going to be doing wire test. My solenoids also got replaced. So my assumption is, there’s a wire issue or a PCM issue.
Onbeat1 is offline
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3856 07-28-2019 09:18 AM
November '18 YJOTM - Vote Now!! bruinjeeper YJ Wrangler Technical Forum 35 12-02-2018 06:24 PM
1987 Jeep Cherokee Cruise Wiring Alyssa4571$ XJ Cherokee Technical Forum 0 11-07-2018 05:11 PM
How to install an RB1 navigation unit in a 1997-2001 Jeep Cherokee Country Jeep XJ Cherokee Technical Forum 14 01-21-2018 04:43 PM
