05 GC Laredo Trans Issue - JeepForum.com
 3Likes
  • 1 Post By jtec
  • 1 Post By yzjwk
  • 1 Post By 99sajeep
post #1 of 8 Old 03-09-2019, 10:50 AM Thread Starter
IggyBrown
2005 WK
Alright, really scratching my head on this one as I have not ever worked on a Jeep till this one. (Was in need of a second vehicle so was gifted to me by my brother)
When starting the vehicle idle is fine and nothing seems amiss. As soon as I put it into any gear and try to drive it acts like it has no power and the rpms just rev into 3-4K just to move a couple inches. If I let the vehicle warmup for 10mins or so there’s no problems and it acts fine.
I figured maybe ESM so took is out and cleaned the graphite streaks off the board and it feels a little bit better when I shift through gears but nothing extraordinary. So a no go there. Waste of 20 minutes.
Trans fluid and filter was changed 5k-ish miles ago, still pinkish red but smells slightly burnt instead of sweet. My grandparents had it towed off their property to their trans guy and he said everything is pointing towards the TCM. He also said it was on the transmission and would cost 1200 to replace; which pardon me if I’m wrong but I thought it was in the drivers side dash?
Vehicle is at 210k and has had constant electrical issues that finally got taken care of and now it’s just this issue and a door blend actuator I need to fix. Any ideas how I should approach this? Maybe tps, solenoid, or the like?
IggyBrown is offline
post #2 of 8 Old 03-09-2019, 11:34 AM
jtec
2014 JK Wrangler
start by confirming the trans fluid level, appearance RED, no silver flakes in fluid.
SCAN for codes - USE a scanner, Post all codes someone will reply. If scanner will not communicate with NAG1 TCM check TSB's
The waiting to get going suggests fliter issue, installation.
Only 1 fluid for this trans ATF4 not universial not one type fits all just ATF4
2008HemiXK likes this.
jtec is offline
post #3 of 8 Old 03-09-2019, 03:20 PM
yzjwk
yzjwk's Avatar
2005 WK
When starting the vehicle idle is fine and nothing seems amiss. As soon as I put it into any gear and try to drive it acts like it has no power and the rpms just rev into 3-4K just to move a couple inches. If I let the vehicle warmup for 10mins or so thereís no problems and it acts fine.
Trans fluid and filter was changed 5k-ish miles ago, still pinkish red but smells slightly burnt instead of sweet. My grandparents had it towed off their property to their trans guy and he said everything is pointing towards the TCM. He also said it was on the transmission and would cost 1200 to replace; which pardon me if Iím wrong but I thought it was in the drivers side dash?
Vehicle is at 210k and has had constant electrical issues that finally got taken care of and now itís just this issue and a door blend actuator I need to fix. Any ideas how I should approach this? Maybe tps, solenoid, or the like?
I agree with jtec , but Just in case youíre not aware, ATF4 is not pinkish red. It should be a dark cherry red and smell like gear oil. If it is actually pinkish or strawberry milkshake colour, that could indicate water in the fluid. Or if is a lighter red and smells more like hot rubber, it could be universal or dexron. Both would be bad. Did the same trans guy who changed the fluid the one that told you the TCM was at fault and located on the trans by chance??
You are correct regarding the TCM placement.
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #4 of 8 Old 03-09-2019, 05:46 PM
Nejeep
Location of TCM depends on which engine/transmission you have. The V6 with NAG1 transmission has a separate TCM located on drivers side near steering column. The V8 engines have a different transmission and no separate TCM, its built into the PCM.
I agree with previous suggestions to get the fluid level checked using the factory procedure which requires reading the fluid temperature and using a level correction chart. Then get the codes read.
06 Laredo - 4x4 V6 - Stone White - Custom LED Cargo Area Lights, Lighted Visors Added - now at 49k miles
97 Laredo - 4.0 4x4 Daily driver for 8 years then relocated to Arizona for 6 more years with the relatives
Nejeep is offline
post #5 of 8 Old 03-11-2019, 02:51 PM
99sajeep
99sajeep's Avatar
2005 WK
Here is a color reference for new ATF+4 fluid:
(old ATF+4 on the left; new ATF+4 on the right)
This is from when I changed fluid/filters on my '05 WK.
T1m likes this.
'99 WJ 4x4 Ltd 4.7L (sold)
'05 WK 4x4 Ltd 5.7L (mine) 200k+ club
'01 WJ 4x4 Laredo 4.7L (daughter)
99sajeep is offline
post #6 of 8 Old 03-12-2019, 12:50 PM
brian-mcBride
I have a 2005 Jeeo Grand Cherokee and just did a spread fluid change. Now it won't shift while in drive and makes a whining sound. What could this be and what could be a answer?
brian-mcBride is offline
post #7 of 8 Old 03-13-2019, 06:10 AM
99sajeep
99sajeep's Avatar
2005 WK
Fluid level good? Correct fluid in it? What transmission do you have? Filter seated correctly?
99sajeep is offline
post #8 of 8 Old 03-13-2019, 02:19 PM
SRT8Em
Check your fluid. Sounds like its low if its not leaking. Some WKs don't have a dip stick and needs to be monitored with a scan tool. I had to do this when I serviced my trans.
15 WK2 SRT
06 WK Laredo
SRT8Em is online now
Another Howell conversion issue: I am stumped! Nucking1Futs Jeep CJ Forum 75 03-12-2019 10:03 PM
trans clutch issue xjpete WJ Grand Cherokee Forum 11 01-24-2019 12:29 PM
terrible uconnect issue mdeez KL Cherokee 2014 & up 1 01-07-2019 10:22 AM
New guy here. 2018 GC with phone connection issue jeep2a New Members/Introductions 0 06-05-2018 09:39 AM
Replace Stock Stereo to Aftermarket - 2007 Jeep Grand Cherokee Laredo hlzma WK Grand Cherokee & XK Commander Forum 0 03-26-2018 01:21 AM
