Help - JeepForum.com
 1Likes
  • 1 Post By jtec
post #1 of 7 Old 05-05-2019, 02:50 PM Thread Starter
evolvingthrumud
evolvingthrumud's Avatar
Help
I have a 2005 Jeep Wrangler sport 4.0 t won’t turn over with key I did get it to turn over by connecting a wire to starter and touching it to battery. It has a bran new battery because it checked out as bad. The head lights turn on the blinkers work the horn the ac radio all work but when you turn the key nothing at all The lights on the dash works but the gages don’t 15 seconds after you turn the key the gages move 1 mm then 10 seconds later the check engine light will finally come on. At this point I can’t get it to a shop without a tow.
evolvingthrumud is offline
post #2 of 7 Old 05-05-2019, 03:00 PM
jtec
jtec's Avatar
2014 JK Wrangler
new battery - might want to check connections both neg and positive both ends, look at fuses in cab and underhood.
If an automatic, shake shifter be sure in P.
If manual check clutch pedal switch.
evolvingthrumud likes this.
jtec is offline
post #3 of 7 Old 05-05-2019, 03:24 PM Thread Starter
evolvingthrumud
I have checked the fuses. Before all this is I went to the store and when I parked it ran rough a little then revel up by it self a few times idling then died then nothing. On the way to the store and back it ran fine. I’m wondering if it’s the ignition switch or/and actuator pin. But why the weird thing with gages and check engine light? How about the computer?
Dave.
post #4 of 7 Old 05-05-2019, 08:02 PM Thread Starter
evolvingthrumud
My 55 y/o blind *** didn’t see the square 20 amp fuse blown looking through the clear top but a multi meter proved it to be bad. $5.00 fix, why it blew who knows but it’s good now!
Dave.
post #5 of 7 Old 05-25-2019, 04:13 PM
mrd05d
Glad you got it sorted. Hope the fix lasts and the fuse blowing was just a fluke.
mrd05d is offline
post #6 of 7 Old 09-11-2019, 07:27 PM Thread Starter
evolvingthrumud
I have a new issue I bought different LED bulbs for my 2005 sport and the 1157 tail lights won’t blink when lights are on. Already have the led flasher the front work like they should I got theses from superbrightleds.com the old ones from O’Reilly. I was told by one person I need resistors On the rear. And one person told me I need non polarity 1157 in the rear, if that’s the case why do the front blink. So now I had to put the O’Reilly back in the rear. But they are so dim compared to the others. Anyone know what’s going on and what I need to do? Thanks
Dave.
post #7 of 7 Old 09-21-2019, 07:39 AM
mspropst
Welcome to the Jeep Forum! Glad you got it sorted out.
______
/¯¯¯|¯¯\____
L/¯¯\\_ |"/¯¯',
..(O)¯¯¯¯ (O)
mspropst is offline
