Black Magic Brakes Brings the Stopping Power for the Jeep Wrangler - JeepForum.com
 1Likes
  • 1 Post By AutoGuide.com
post #1 of 1 Old 11-05-2019, 10:58 AM Thread Starter
AutoGuide.com
Sponsored Editorial Content
If you’ve done modifications to your Jeep Wrangler — like fitting larger tires, installing off-road armor, or adding weight in the form of other accessories, you’ve likely noticed your braking performance has taken a hit. Larger tires effectively reduce the mechanical advantage of your braking system, allowing the wheels to transmit more torque to the axle. While adding weight is, well, adding weight; the heavier the vehicle, the greater its momentum, and the longer it’ll take the braking system to convert that forward momentum into friction heat. Read More >>
marwen likes this.
AutoGuide.com is offline
