ZJ with no lift and 31" tires - JeepForum.com
post #1 of 9 Old 07-31-2010, 12:02 PM Thread Starter
Pierre_r
Pierre_r's Avatar
1989 XJ Cherokee
I tried to serch but i found nothing.
I want to see grand cherokee ZJ with no lift and with 31" tires
Pierre_r is offline
post #2 of 9 Old 08-01-2010, 01:25 AM
chicagoniner
chicagoniner's Avatar
start your cutting
02 Subie REX
Looking for Custom Drums? Check out
chicagoniner is offline
post #3 of 9 Old 08-01-2010, 08:17 AM
rritch
Here is mine with 31x10.5x15 before I installed the 2.25" BB. You can run it but they are going to rub. The front ones rubbed on the front bumper when backing up and turning and the rears would rub on the wheel wells when I hit a bigger bump. This was all on road I never tried to wheel it with that setup. I would suspect that you might really rub pretty badly wheeling it. The 2nd pic is after the 2.25" BB. Still rubbed just a little on the front bumper. Just a slight bit of trimming resolved that. I think it looks better too
98 ZJ 5.2L Limited, 2.25" Budget Boost, 31x10.5x15 Definity Dakota MTs, Westin Safari Bar, Hella 500 Driving Lights.
rritch is offline
post #4 of 9 Old 08-13-2010, 08:21 AM
ctschmidt
With the 2.25 lift will the back springs pop out or anything like that if you go wheeling??? I heard that the spring is only on the spacer and doesnt have anything else to stop if from coming out. If i welded a bar going down inside the spring will this make it safer you think?
ctschmidt is offline
post #5 of 9 Old 08-13-2010, 01:17 PM
Timbo269
Timbo269's Avatar
Your better bet would be to invest in sum Bumpstops from daystar or fat bobs garage.
Timbo269 is offline
post #6 of 9 Old 08-13-2010, 01:22 PM
PaLftr
I have 3" lift and still rub 31s on the front bumper metal.
ZJ DD, WW. 4.go litre modded. 3", 31's. Needs armor.
PaLftr is offline
post #7 of 9 Old 08-13-2010, 02:25 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
1994 ZJ
Originally Posted by chicagosynergy View Post
start your cutting
what is up with all on this forum. 31's will fit with NO, i repeat NO cutting!!!!!
31's on my ZJ. the only place it rubs with stock wheels is on the LCA at full lock. no fender or bumper rub at all. they are only 31's.
1994 ZJ-- bone stock for now
2005 GMC 2500HD 496 C.I. tows it all
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #8 of 9 Old 08-13-2010, 02:29 PM
underpowered
1994 ZJ
even after removing the sway bars, it only rubbed when at full stuff on the top of the fender. a little bumpstop would solve that
tire is the bump stop in this pic, on the fender
post #9 of 9 Old 08-13-2010, 03:20 PM
MurdaJs
Heres my only stock height with 31x15x10.5 GY Wrangler A/Ts
Courtesy of Google Earth
I know its a ****ty pic, but I the only rubbing I had was while turning and reversing on a slope, like backing out of a driveway. Probably would have rubbed in the front at full stuff and lock if disconnected though..
Oh and I found out later on that I have the Up Country suspension package which is basically a stock 3/4 or 1" lift.
MurdaJs is offline
TJ's with Rubicon Flares, 4" lift, with 33" or 35" tires HANKiE Jeep Picture Requests 12 05-08-2012 09:23 AM
TJ with 31" Tires and 1 - 2" body lift . NO Suspension Lift HighRoller02TJ Jeep Picture Requests 5 07-03-2011 11:32 AM
Yellow TJ with 2"-3" of lift, 31" Tires and BLACK wheels rmb2485 Jeep Picture Requests 9 02-07-2011 03:36 PM
Cj7's with 3" or 4" lift and 33" or bigger tires. No bl, no cutting JURKFASE Jeep Picture Requests 7 05-17-2010 02:42 PM
Green TJ Saraha 4" Lift 2"BL 35" Truxxus Tires John_Wayne Jeep Picture Requests 1 12-03-2009 10:08 AM
