Monstaliner interiors and exteriors - Page 58 - JeepForum.com
 38Likes
post #856 of 1397 Old 09-09-2014, 12:56 PM
AZdEvilYJ
Keyboard Cowboy
AZdEvilYJ's Avatar
Originally Posted by GB_YJ_GUY
thanks man. build thread is over on pirate 4x4 under jeep hardcore tech. 92 yj, 97 12 valve cummins, nv4500, valair street/strip 13" clutch and flywheel. np241 transfer case with new input shaft, SYE kit and custom tom woods drive shaft. 78 dana60 rear and 44 up front(soon to be upgraded to a 60). replace rear half of the frame and front section due to severe rot. custom lots of stuff.. lol
I imagine that thing will straight up get it
'95 YJ 2.5L
March '19 YJ of the Month!
My Build Thread
Do your best and caulk the rest
-Albert Einstein
AZdEvilYJ is offline
post #857 of 1397 Old 09-09-2014, 02:25 PM
GB_YJ_GUY
you bet!! I'm still breaking in the clutch but it still moves out and the motor is still all stock
GB_YJ_GUY is offline
post #858 of 1397 Old 09-12-2014, 03:52 AM
80Jenegade
1980 CJ7
I am debating on painting the exterior of my Jeep or doing Monstaliner. So I have some questions.
Those who have done Monstaliner, are you happy with the results down the road and does the color hold up well?
I use my jeep and it is not babied so I dont want to tear off new paint when I'm wheeling.
I will prep everything well and take my time so no worries there but I want to be happy after I cover the entire exterior with Monstaliner.
Just looking for Opinions
Thanks in advance!
Beat it to fit, Paint it to match
80Jenegade is offline
post #859 of 1397 Old 09-12-2014, 06:42 AM
1ofakind
I'm finally placing my big order for 4 gallons of monsta and 1 gallon of chassis saver today. Couple questions though.
Can I use acetone to clean the sanding dust off? If some spots are down to bare metal should I spray some primer and sand it again or would it stick ok?
1ofakind is offline
post #860 of 1397 Old 09-12-2014, 06:44 AM
1ofakind
Originally Posted by GB_YJ_GUY View Post
92 Yj white and black monstaliner. White is sprayed black was rolled.
took first for best 4x4 at the car show over the weekend. I'd Say 90% of people that came up had to comment and touch the paint. Then they try to guess what it is before asking. Lol
How much monsta did you use? I'm about to order to do my entire jeep exterior and interior
1ofakind is offline
post #861 of 1397 Old 09-12-2014, 07:15 AM
GB_YJ_GUY
i believe it was 4 gallons of the white.
post #862 of 1397 Old 09-12-2014, 12:32 PM
1ofakind
Just ordered my monsta! Going with midnight special (kind of matches my truck). Got two gallons of tint able and 2 gallons black with a gallon of chassis saver!
1ofakind is offline
post #863 of 1397 Old 09-13-2014, 12:46 PM
Yesfan70
Yesfan70's Avatar
2018 JK Wrangler
Originally Posted by Dukem10 View Post
All finished painting, and decals on! If you need anything or need to ask a question just ask!
Wow! That looks great! If I done anything different, I maybe would have Monsta lined the headlight rings the same color and went with the clear signals over amber.
But that looks great! The soft top's color is a great match too!
2018 JKUR
Only in a Jeep
Yesfan70 is offline
post #864 of 1397 Old 09-13-2014, 01:15 PM
lynskynbnd
lynskynbnd's Avatar
1987 YJ Wrangler
A year and a half later and many wheeling trips, the Monsta is holding up Very Well!
Originally Posted by lynskynbnd View Post
Dark Burnt Orange
It's still wet and in the bright sun. It should dry darker.
  • 3 gallons were used. I had about a quart left over. mixed about 2 oz MEK in each gallon when cleaning all the color from the DBTO can.
  • Sprayed with Walcom shutz gun at 70 psi (60 psi first coat) 5 turns out.
  • Had 2 cans to swap when empty.
  • 1 gallon did first coat. Second coat was sprayed heavier and used a gallon and a half.
  • I hit the floors, entries, and tail gate with some extra liner. Spraying heavy gives a larger, rounded texture. I did a light mist last to get the fine texture I desired.
  • By the time you get to the end of painting you'll get the idea of how you want it to be for your preference.
  • The whole inside of the tub, half doors, tail gate, roll bar, the whole outside of the body, and the front inner fender wells were all sprayed.
  • After I finished spraying and pushed it outside into the sun I found a few spots that needed touching up. I used a mini roller and sponge from the
    mini kit to take care of those spots.
Full photo album on Google Plus
Full album on Daily Driver Jeep Club facebook
lynskynbnd is offline
post #865 of 1397 Old 09-13-2014, 05:26 PM
roughknight69
roughknight69's Avatar
Per a members request
Build thread
roughknight69 is offline
post #866 of 1397 Old 09-13-2014, 07:19 PM
1ofakind
Thanks so much!! Looks so good exactly how I want mine when I'm done haha
1ofakind is offline
post #867 of 1397 Old 09-13-2014, 07:37 PM
roughknight69
No prob! This is only one coat of monsta to, I'm putting the second gallon on next spring.
Build thread
post #868 of 1397 Old 09-13-2014, 07:47 PM
1ofakind
Wow so I should have plenty. I ordered 2 gallons of midnight and 2 gallons black
1ofakind is offline
post #869 of 1397 Old 09-14-2014, 02:48 AM
roughknight69
You'll have more than enough
Build thread
post #870 of 1397 Old 09-16-2014, 03:01 PM
swannytd
I am almost finished with my 93yj. Two gallons of black for the interior and part of the exterior then one gallon of apocalypse.
swannytd is offline
monstaliner
Tinted Monstaliner Painted Exteriors roughknight69 Jeep Picture Requests 6 06-12-2017 01:32 PM
Customized Interiors!... Thisisaustin Jeep Picture Requests 20 04-26-2014 08:48 PM
TJs with two toned interiors? private Jeep Picture Requests 0 04-13-2011 03:13 AM
Early XJ interiors ArrizX Jeep Picture Requests 3 06-22-2009 09:22 AM
XJ Interiors -Shoey- Jeep Picture Requests 13 02-24-2009 11:25 PM
