Lets see some Unlimited LJs - Page 684 - JeepForum.com
 484Likes
post #10246 of 10276 Old 04-29-2020, 07:57 AM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
Good eye on the wheels - even looking for it it took me a few minutes to see the difference.
Build Thread:
Swing Away / Swing Down Tire Carrier:
NashvilleTJ is offline
post #10247 of 10276 Old 04-29-2020, 09:37 AM
06JeepXKHEMI
06JeepXKHEMI's Avatar
Originally Posted by jeepbro's View Post
Looks sharp for 226k!
I picked mine up back in January with 176k and looks decent but not quite that good! I need to do a good detail, and I plan to replace the hood because it has a dent and typical spyder cracking in the factory clear coat but it should be good after that.
Also, don't know if you realize it, but your back passenger wheel is a different MOAB wheel than the other 3. One of my spares is the same as your other 3, and my other 4 are the same as your passenger rear.
I'll be pulling the tire and selling it eventually to have a matched set if your interested in swapping it for one that matches the other 3.
Man good eye! I hadnít even noticed until the other day. I have a spare which is the same as the others so Iíll use that and use this as a spare. Itís definitely cleaner than the others so the PO must have needed a replacement, probably a knock off
05 LJRubi Currie 4" Springs, Savvy Fox shocks, MC trackbars, MC CA's single adj lower double uppers, 37x13.50 Cooper STT Pros on 17x9 ATX Ravine, MC Overlines front, Genright rear, Revolution 5.38s, Carolina Driveline driveshafts, MCAI
06JeepXKHEMI is offline
post #10248 of 10276 Old 04-29-2020, 01:36 PM
bparsel
Just pulled my '05 out after 6 months of hibernation.
206k
Mud Machine likes this.
bparsel is offline
post #10249 of 10276 Old 04-29-2020, 01:43 PM
jeepbro's
I think that style wheel is from the 2006's. The extra 'rib' on it came out around '05/06. I remember my friend had a new Rubicon back in 06 and it had that style from the factory.
2002 tj sahara 3" lift 35" km2, AtoZ rockers, 8k warn, 4.56 gears, lock-rites front and rear
jeepbro's is offline
post #10250 of 10276 Old 04-29-2020, 02:32 PM
06JeepXKHEMI
Well all my wheels are like the front passenger, in that pic. On the passenger rear is smooth like that. And itís cleaner so Iím assuming the PO replaced it at some point
post #10251 of 10276 Old 04-30-2020, 12:14 PM
jeepbro's
Yeah thats likely the case, the wheels with the lip were probably 2005 and 2006 with the smooth ones being 2003-2004.
Does anyone else with a 6spd LJ have an issue with your Jeep feeling slower than normal or low on power from what it should be?
Mine idles fine, seems like it has all the power it should at low RPMs but once you get on it at like 2200 or above it feels like it hits a wall powerwise and doesnt accelerate like it should. If I stomp it at that rpm it starts to go and feels like you let off half way around 2500 rpm and climbs at that slower rate from there on...
Trying to accelerate in 4th at 3k rpm I can have it at the floor for what seems like forever before it finally gets to 4k rpm and just doesn't move like I think it should, its almost hard to accelerate to merge on the highway and thats trying to run it as high as I can in each gear.
Almost feels like my 02 TJ 5spd on 4.56's, 35's, heavy armor and bumpers and hard top accelerates better than my stock 6spd LJ Rubi on 285s...
06JeepXKHEMI likes this.
post #10252 of 10276 Old 04-30-2020, 03:57 PM
mukluk
mukluk's Avatar
@jeepbro's
What you describe sounds like you may have a problem with your catalytic converters getting clogged. An easy way to verify if this is the case is to connect a vacuum gauge to an intake manifold port and see what it does as you hold the engine at higher revs -- a normal engine will exhibit increased vacuum from idle to high revs, while one with an exhaust obstruction will show the manifold vacuum lower at high revs than at idle.
2000 TJ SE
2005 LJ Rubicon
mukluk is online now
post #10253 of 10276 Old 04-30-2020, 05:01 PM
06JeepXKHEMI
Mine feels that way and Iíve done a lot of maintenance, including plugs, cats, full exhaust etc... may do a carbon cleaning next. We both have quite a lot of miles. Time to regear for you as well as myself. Deeper gears will help.
Savvy lift done, on the alignment rack now getting everything dialed in
post #10254 of 10276 Old 05-01-2020, 06:57 AM
jeepbro's
Yeah I had a parts jeep I swapped the cats because one on my jeep did blow out and I thought it made a difference at first but it may have been placebo because it felt sluggish again a few days later.
Ended up hollowing out my old cats, both the 2 pre cats and the rear cat from my original exhaust and put it back on with not much difference.
And I shouldn't need gears being a 6spd manual with factory 4.10's and only on 285's. Its actually a better/lower ratio in all gears with that tire size than my 5spd TJ on 35's with 4.56's. I'm thinking of doing Seafoam treatment again.
I do have a lifter tick occasionally so I'm wondering if it is causing that valve to not open all the way and result in lower feeling power but I'm not sure. I don't want to tear it down and replace all that just for it do do the same thing.
post #10255 of 10276 Old 05-01-2020, 07:02 AM
jeepbro's
Also, anyone have pics of a black LJ with Silver flares?
I wanted to get some paint matched flares for the Rubicon, but there's a silver set for sale locally and was thinking that might look good to. I know the Rocky Mountain edition jeeps had a grey/graphite painted flares that looked sharp.
post #10256 of 10276 Old 05-04-2020, 05:53 PM
06JeepXKHEMI
The build is coming around. 315/75 Geolander MTs installed. Pretty cool story with Yokohama.. growing up in Jeeps, my dad has a set of Geolanders on his ZJ Grand Cherokee, back 2001! To incorporate them into my build now is pretty awesome.
post #10257 of 10276 Old 05-11-2020, 04:16 AM
VirtualRussel
What size lift are you running? What’s the load rating on those tires?
Great looking Jeep!!
'85 CJ-7
'05 Rubicon LJ
'12 Sahara JK
VirtualRussel is offline
post #10258 of 10276 Old 05-13-2020, 06:17 PM
en480c4
Originally Posted by en480c4 View Post
Here's probably the last shot of my LJ , in the driveway with its replacement.
Tank '15 JKU Willys
More room with the arrival of our second daughter two weeks ago.
And three years later, I traded the JKU for a new Touareg for the wife and brought this home today.
2005 LJ with 39k miles.
And I picked up a used soft top in great shape Monday that will go on this weekend.
Edit:
Dropped the plow yesterday.
For a 15 year old Jeep in New England, this thing is remarkably clean. Iíll be cleaning up the few spots that arenít this summer.
NHfireLJ likes this.
Ian
2005 LJ
en480c4 is offline
post #10259 of 10276 Old 05-13-2020, 07:54 PM
visorclown
New Rig. 35" Mickey Thompson. 4" skyjacker lift with 1.25" BL.
visorclown is offline
post #10260 of 10276 Old 05-14-2020, 04:16 AM
06JeepXKHEMI
Originally Posted by VirtualRussel View Post
What size lift are you running? Whatís the load rating on those tires?
Savvy 4Ē, load range E. Most 16Ē tires will be. Iíve never had an issue when theyíre filled to correct psi
Next up is to mount spare and find the ever elusive khaki soft top that this cane with.
NHfireLJ and voodooridr like this.
lj
Lets see some silver lifted Unlimited LJs BFG Man Jeep Picture Requests 34 03-12-2018 02:08 PM
Lets see the 2'' BB Jeepkid09 Jeep Picture Requests 27 07-23-2013 08:05 PM
YJ.. Lets see some! TMC23 Jeep Picture Requests 21 09-17-2009 07:54 AM
