Lets see some Unlimited LJs - Page 119 - JeepForum.com
 429Likes
post #1771 of 10233 Old 05-05-2010, 08:28 PM
xantasm
2015 WK
Originally Posted by Fargo View Post
I don't know if I put a link to my most recent picture here or not. But here it is. Still stock but a 2" lift is coming soon.
Whats wrong with you , get out there and start modding that thing
xantasm is offline
post #1772 of 10233 Old 05-05-2010, 08:44 PM Thread Starter
Fargo
Fargo's Avatar
Don't you know these are collectors items man. I'm keeping mine stock so it increases in value more. OK so that might not happen.
I am looking into some lifts right now. My plan is to start with a 2" spring lift and later add a body lift to accomadate 33s. I should get the 2" lift this summer. I don't know when I'll get the bigger tires.
My hope is to get it to look something like the picture below when I'm done. Except that I have frame mounted sliders and will have a body lift instead of all suspension. This guy has the 3" bds and I will run the 2" BDS with BL. I like the stock but bigger look.
6spd manual
LJ Owners Group member #110
Fargo is offline
post #1773 of 10233 Old 05-05-2010, 10:42 PM
787
787's Avatar
This was mine with a four inch lift and 33" tires
787 is offline
post #1774 of 10233 Old 05-06-2010, 09:25 AM Thread Starter
Fargo
Fargo's Avatar
Good looking Sahara's guys. I had decided on a 2" lift with plans to add a BL and 33s later. Now I see all these nice Jeeps and keep thinking "will that be big enough"... I guess for my needs it is. Although I love the big Jeeps, my priority needs to remain on long distance driving with enhanced offroad capability.
6spd manual
Fargo is offline
post #1775 of 10233 Old 05-06-2010, 09:32 AM
JEEP-DADDY
JEEP-DADDY's Avatar
I've been riding around with a 2" BB and 33's.....its perfectly fine on road and handles almost stock. I can however see where it would rub off road.
Steve
2005 LJ
JEEP-DADDY is offline
post #1776 of 10233 Old 05-06-2010, 11:13 AM
elephantrider
here's a few more shots.
next to a 2010 jk 2 door.
and a few shots from last weekends run
elephantrider is offline
post #1777 of 10233 Old 05-06-2010, 02:02 PM
NorCalCon
NorCalCon's Avatar
Long arm upgrade and doorless.
NorCalCon is offline
post #1778 of 10233 Old 05-06-2010, 05:43 PM
electrichead
electrichead's Avatar
Thats a great shot. Did you take that from a motel balcony?
electrichead is offline
post #1779 of 10233 Old 05-06-2010, 09:34 PM
NCUNLIMITED
NCUNLIMITED's Avatar
Got new 33x12.5x15 Duratracs on today. Love the looks and ride.
Going camping and wheelin in two weeks and then up to the outer banks next month, Can't wait to see how they do
NCUNLIMITED is offline
post #1780 of 10233 Old 05-07-2010, 07:10 AM
elephantrider
it was from the 4th floor of the office i work at.
post #1781 of 10233 Old 05-07-2010, 03:49 PM
TwistedDrum5
TwistedDrum5's Avatar
Here is a picture of my front tire (305/70/16) at full stuff disconnected running my lift setup. With a 2" BB lift and 33"s you would likely tear your flares off if you ever disconnected your front sway bar. If you stayed connected you should be fine.
If you look at my avatar that's 33 on 2" pucks. I trimmed the fender and added 1 hockey puck for bumpstops, about an inch, and I only rub when I'm fully flexed and turning. That's disconnected too.
CHRISTIAN JEEP member #173
TwistedDrum5 is offline
post #1782 of 10233 Old 05-07-2010, 04:23 PM
xantasm
2015 WK
I suspect Fargo isnt interested in cutting his limited edition flares to allow more flex which is why I commented what I did. I didnt say it couldnt be done, just that he would likely tear his flares off.
xantasm is offline
post #1783 of 10233 Old 05-07-2010, 05:15 PM Thread Starter
Fargo
Fargo's Avatar
Yeah, I won't be cutting my flares. I did see Xantasms picture. Sorry I didn't comment back. I think you may have have missed the part I said I would be running a body lift as well. My plan is to run a 2" spring plus body lift. I see guys all the time with 2" OME lifts and body lifts so I figure it shouldn't be any different with a BDS 2" lift plus body lift. Besides its all in the bumpstop.
The way I see it I could run 33s with my stock setup if I lengthend the bumpstops enough. I'd be on them all the time, but I wouldn't rub. More realistically though, I figure I will gain an inch of clearance by raising the body an inch and then I will extend the bumpstop another inch. That along with a 2" lift should give me enough room to clear 285/75/16s as well as gain an extra inch of suspension travel. Am I missing anything?
6spd manual
Fargo is offline
post #1784 of 10233 Old 05-07-2010, 07:03 PM
glockster
glockster's Avatar
Wheel spacers?
Marco
glockster is offline
post #1785 of 10233 Old 05-07-2010, 09:16 PM Thread Starter
Fargo
Fargo's Avatar
Originally Posted by glockster View Post
Wheel spacers?
No, I was planning on using your Bridgers
Most likely I would run wheel spacers. I found H&R springs makes one for the TJ that is hubcentric and only .6" deep. That would give me a backspace of 4.4". (They also have 25mm and 30mm or .98" and 1.18") I might give that a try if I can find it for a decent price. I'd like to keep things tucked in as tight as possible. My only concern with the skinny spacers is they use longer studs instead of new studs on the adaptor. But since it is hub centric the studs don't carry any weight. So I think it might be OK. But I'll do more research when I'm ready for spacers or rims.
2005 Jeep Wrangler Applications || H&R Special Springs, LP
Well one sure way to know is to live and learn lol. With my tires (305/70/16 MTR/K) I would have eaten my flares had I not had RE 3.5" springs and I am running a 1" Tera BL. And Glockster is right if you are gonna run the Moab's wheel spacers should be on your list, otherwise get new rims with better backspacing.
Hey now, your scaring me. I thought the general consensus here was that a 2" lift with body lift was enough for a 285/75/16. How much bumpstop is needed to keep the tires out of the fenders. I suppose if I absolutely had to I could run a 1 1/2" bumpstop. But I hate to do that and give up any extra suspension travel I gained with my lift. I could also do a 1 1/4 body lift for that little bit extra. But I think I'd rather stick with the smaller body lift.
6spd manual
Fargo is offline
lj
Lets see some silver lifted Unlimited LJs BFG Man Jeep Picture Requests 34 03-12-2018 02:08 PM
Lets see the 2'' BB Jeepkid09 Jeep Picture Requests 27 07-23-2013 08:05 PM
YJ.. Lets see some! TMC23 Jeep Picture Requests 21 09-17-2009 07:54 AM
