Frame Height From Ground-YJ - JeepForum.com
post #1 of 5 Old 12-15-2008, 10:32 PM Thread Starter
chocflip201
This could either be taken as a picture request or a measurement request, I need to find out which tire/suspension combo's give a certain amount of break-over height, or frame height between the wheels on the YJ's, so a measurement taken here: From the bottom of the frame, to the ground on a flat surface. (I need to set a height on my Jeep of about 24" from frame to ground and I need to know what amount of lift/tire combo I use to achieve this.)
Please include The size of tire you have (inflated for measurement please) the amount of suspension lift, amount of sag, and any other factors that would affect this measurement. Thank you- Chocflip201
chocflip201 is offline
post #2 of 5 Old 12-15-2008, 10:38 PM
welchct
35"
1.5" BL
FRONT:
SOA, 4" front yj springs with 1.25" lift shackle, out board springs, rockwells, 46" claws
REAR:
Custom built four link, 14" coil overs
13-14" lift
ORS
Off Road Specialties
welchct is offline
post #3 of 5 Old 12-15-2008, 10:51 PM Thread Starter
chocflip201
Is that measurement with the weight of the jeep on the suspension? If so then according to your measurements (I will be running a 37" tire, so I will lose 4 inches of height by using a 37" tire, which would bring your frame height down to 31". so to get my height to 24 then I would need to lose 7" of suspension. bringing my total to 7" of lift, and a 37" tire. Thanks for your help.
Please everyone who owns a YJ, more measurements to compare to (always better to check more than once, so I only have to build once.)
post #4 of 5 Old 12-16-2008, 10:28 PM Thread Starter
chocflip201
Sorry I hate bumps just like everyone else but, I'd like to get at least 3 or 4 different Measurements on Jeeps to get the most accurate reading. . anyone?
post #5 of 5 Old 12-18-2008, 11:20 AM Thread Starter
chocflip201
I'll try one last bump. If not this thread will die ha. I'll give you a if you go measure for me..
Ground Pounder Fab bumpers Camo Deere Jeep Picture Requests 168 11-03-2017 12:52 PM
Stock height with 33s OUrunner Jeep Picture Requests 10 01-26-2013 07:45 PM
Stock height XJ on Ravines 83iS Jeep Picture Requests 0 10-16-2009 09:12 PM
32" Radial Ground Hawgs JRussum Jeep Picture Requests 1 11-16-2008 02:52 PM
Ground Hawgs Kasia Jeep Picture Requests 0 11-19-2007 07:36 PM
