Spark Plugs - JeepForum.com
post #1 of 8 Old 07-29-2021, 03:38 PM Thread Starter
Zigged79
1979 FSJ Cherokee
Spark Plugs
What ARE YOU GUYS RUNNING for an AMC 360 HEI, Spark plugs. What Gap?
Zigged79 is offline
post #2 of 8 Old 07-30-2021, 06:00 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
You can usually open them up .005 to .0010 over stock if you want.
Paperwork will ruin any military force.
Chesty Puller
jeepdaddy2000 is online now
post #3 of 8 Old 07-30-2021, 07:43 PM Thread Starter
Zigged79
1979 FSJ Cherokee
I think they do need to run a little hotter. What brand and number are you running?
Zigged79 is offline
post #4 of 8 Old 07-31-2021, 08:55 AM
jeepdaddy2000
1971 CJ5
Why do you think this? Are you getting fouling? What plug are you currently running?
Hotter plugs are better for stop and go driving and short trips (fouling issues), cooler plugs are better for loads or high RPM work (heat dissipation).
I believe the stock plug is a Champion N12Y, or a variation of that.
Be sure your engine is in proper tune before swapping plug ranges.
I'm not currently running an AMC motor, but have experience with them as well as HEI upgrades and plugs, so that is where my advice is coming from.
Chesty Puller
post #5 of 8 Old 07-31-2021, 05:17 PM Thread Starter
Zigged79
1979 FSJ Cherokee
I've been running Autolight 65. They don't seem to last very long. They act fouled. when I put a new set in it runs fine, but not as long as i would think it should. Only 3,000 miles.
Zigged79 is offline
post #6 of 8 Old 08-01-2021, 01:05 AM
jeepdaddy2000
1971 CJ5
The act fouled or they look fouled?
Are they all fouled or a specific cylinder?
Are they black?
Brown?
White?
Sooty?
oily?
Fouling can be anything from over rich jetting to a malfunctioning PCV system. The trick is to insure there isn't an underlying issue.
Chesty Puller
post #7 of 8 Old 08-01-2021, 11:27 AM Thread Starter
Zigged79
1979 FSJ Cherokee
The plugs have only a slight tan color. I will be going over everything soon to make sure everything else is in order.
Zigged79 is offline
post #8 of 8 Old 08-01-2021, 11:41 PM
jeepdaddy2000
1971 CJ5
IMHO, slightly tan is perfect.
Chesty Puller
