Overheating Issues / Cooling System Questions - Page 2 - JeepForum.com
post #16 of 25 Old 03-18-2015, 05:53 AM
RockRollin
RockRollin's Avatar
1990 FSJ Wagoneer
The catch can is a passive tank, meaning it stores expanded coolant so it can be drawn back into the radiator when contraction occures when the cooling system cools down. So any tank would work as long as the feed line does not leak and the end in the tank stays below the level of the coolant. The stock tank in my 90 mounts next to the radiator against the radiator core support. So anything that fits that space, and holds around a half gallon would work.
Gixxerphil has a thread titled "parting a 78 wagon" er something like that, could check with him or find another used one at a salvage yard. Bjs offroad has an aluminum tank but it's kinda pricey. There are surely many from other vehicles at a salvage yard that would work.
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #17 of 25 Old 03-18-2015, 12:48 PM Thread Starter
73wagon
1973 FSJ Wagoneer
ok I ordered the radiator that you recommended today! Says it shold be here by Tuesday and then Ill get it put in.
Do you think I should go ahead and order the fan as well or install the radiator and see if it runs cool?
If I order the fan that you recommended should I buy a new clutch for it?
73wagon is offline
post #18 of 25 Old 03-18-2015, 03:59 PM
RockRollin
RockRollin's Avatar
1990 FSJ Wagoneer
Hard to say what shape the clutch is in till its inspected. I'd wait on the clutch. Fact is the flex fan may cool it at idle with a new radiator and a good flush, but if problems persist it's the next thing to go imo.
"I like fun" Edd
post #19 of 25 Old 03-18-2015, 09:13 PM Thread Starter
73wagon
1973 FSJ Wagoneer
just to be clear are you saying that my current fan may cool it at idle?
was also thinking of putting a new thermostat do i use a 195* one?
73wagon is offline
post #20 of 25 Old 03-19-2015, 06:57 AM
RockRollin
RockRollin's Avatar
1990 FSJ Wagoneer
You have three things letting you're cooling system down as it is.
Leaking radiator
overflow container
low cfm fixed fan
Any one of these will effect the cooling capabilities, the biggest being the radiator then the low cfm fixed fan, and finally the overflow container. To be at maximum efficiency correct all three, but any one of these can improve performance of the system.
Don't overlook the chemical flush, it will make a difference. There are many: Prestone, Zerex, etc, etc.......
Pour it in, run for 200 miles, and thoroughly flush without thermostat installed.
A 195 thermostat is the factory recommendation.
"I like fun" Edd
post #21 of 25 Old 03-25-2015, 05:05 PM Thread Starter
73wagon
1973 FSJ Wagoneer
its here!! I am gonna install it today or tomorrow, will post pics!
73wagon is offline
post #22 of 25 Old 03-28-2015, 02:38 AM Thread Starter
73wagon
1973 FSJ Wagoneer
got it all ready, even added a new transmission cooler
tried to install this radiator I bought from ebay that said it would fit a 1973 wagoneer and it does not fit!
The bolt pattern does not match up, that radiator is not wide enough.
73wagon is offline
post #23 of 25 Old 03-28-2015, 05:34 AM
RockRollin
RockRollin's Avatar
1990 FSJ Wagoneer
Thats frustrating.
My radiator and core support measures 30", outside of flange fwiw. Yours looks exactly like mine.
how much separation do you have from the fan blade to the radiator.
"I like fun" Edd
post #24 of 25 Old 03-30-2015, 01:28 PM Thread Starter
73wagon
1973 FSJ Wagoneer
I am thinking about just replacing it with the OEM version from autozone. It is copper and brass. What do you think of that?
73wagon is offline
post #25 of 25 Old 04-01-2015, 09:23 PM Thread Starter
73wagon
1973 FSJ Wagoneer
this is really frustrating, I just ordered another one on ebay and it was advertised as being 30 5/8" wide which would totally work. I got it today and it measures exactly 29.5" wide
73wagon is offline
cooling system , radiator
