ignition key cylinder - JeepForum.com
post #1 of 4 Old 05-23-2019, 04:25 PM Thread Starter
rustbucketj10
got a j10 1979. when to start it and the key kept on going and now the key cylinder is locked forward. The key comes out but the cylinder is stuck past where the starter would be engaged. Any one replaced the cylinder?? looks like i got to pull the steering wheel ...xxxx
rustbucketj10 is offline
post #2 of 4 Old 05-23-2019, 06:57 PM
CSP
Lots of people have replaced the cylinder.
Google "Saginaw ignition cylinder" and you'll find all kinds of info to get it done. It's a GM column used in countless thousands of vehicles through the years.
CSP is offline
post #3 of 4 Old 05-24-2019, 09:14 AM Thread Starter
rustbucketj10
thanks for the search tip. I have the clip in kind. Wasnt to bad taking out. Now I got to put a new one back in and start it. The hardest part was finding where that clip was to push in.
post #4 of 4 Old 05-24-2019, 05:56 PM Thread Starter
rustbucketj10
went to put the new clylinder in and i think the problem is the steering wheel is locked up... i tried to shake it back and forth to move the key back but wont work..
Key sticking in ignition on ACC... Help! superheady WK Grand Cherokee & XK Commander Forum 8 01-07-2019 10:13 AM
95 ZJ nothing when ignition key turned to start muddflow ZJ Grand Cherokee Forum 41 11-16-2018 02:02 PM
Ignition and ign. key sometimes doesn't work muddflow ZJ Grand Cherokee Forum 19 11-05-2018 04:19 PM
Chasing Gremlins Nereussailor Jeep CJ Forum 11 09-01-2018 05:41 AM
JEEP WJ 2001 Ignition Locked, Key Won't Turn, Need Help To Diagnose BuckWild51 WJ Grand Cherokee Forum 18 01-09-2017 11:14 AM
