Ignition Control Module (Ignitor) - LX-401 1975-1977 AMC Jeep - JeepForum.com
 1Likes
  • 1 Post By CSP
post #1 of 5 Old 06-21-2019, 04:20 PM Thread Starter
TONYSPEGGY
TONYSPEGGY's Avatar
1975 FSJ Cherokee
Hello, just doing some updating on my 1975 Jeep Cherokee S and I was replacing the Ignition Control Module
and found the single black ground wire taped up under Ignition Control Module, surely this ground is to be grounded
somewhere, but where ? Thanks
TONYSPEGGY is offline
post #2 of 5 Old 07-01-2019, 09:16 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
The black wire was about 6" long and had a bullet connector on the end. It should be mated to another black wire with the female end of that connector, look around the fender in case it has just dropped down. If not then you can ground it to anywhere but make sure you get a good ground path or the module can be damaged.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #3 of 5 Old 07-04-2019, 08:24 AM Thread Starter
TONYSPEGGY
TONYSPEGGY's Avatar
1975 FSJ Cherokee
Thanks, The only running problem that I have is driving at 75 mph after a while it dies and always restarts again , maybe this is the problem, the ground ?
post #4 of 5 Old 07-08-2019, 01:08 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
Could be a cracked coil, the module should eventually melt if it had nowhere for the energy to dissipate. they heat up and the crack opens and you die.
post #5 of 5 Old 07-14-2019, 12:01 AM
CSP
The ignition system in that year was Prestolite and earned the nickname of Prestocrap for a reason. I've swapped one of mine out for a GM HEI distributor (258 inline 6), and the other for a '78-91 Jeep Duraspark distributor w/large Ford cap and rotor and Ford TFI coil (401 v8). This one happens to be controlled by the GM EFI system that's also installed, but you can use a GM HEI ignition module with the Duraspark distributor. Google Jeep stealth HEI for more info.
seth13_1984 likes this.
CSP is offline
