Bent pushrods in a 258 - JeepForum.com
 1Likes
  • 1 Post By jeepdaddy2000
post #1 of 6 Old 10-15-2021, 04:24 AM Thread Starter
Submariner
Submariner's Avatar
2016 JK Wrangler
How in the hell did I get 5 bent push rods in my 258. pulling head tomrrow to see what is inside cylinders.
suggestions on what might have happered?
just bought this 80 J10 Engine ran well, drove it home, then this happened.
It had sat for 15 years.87K miles on it.
Submariner and you wonder why I am this way LOL
Submariner is offline
post #2 of 6 Old 10-15-2021, 05:01 AM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Bent/stuck valves, broken valve springs, faulty/broken rocker arm pivots, collapsed lifters, extreme over-revving or the engine backfiring are some possible causes for bent pushrods.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #3 of 6 Old 10-15-2021, 06:13 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Don't forget the infamous "3/4 race cam" .
Submariner likes this.
Paperwork will ruin any military force.
Chesty Puller
jeepdaddy2000 is offline
post #4 of 6 Old 10-15-2021, 10:17 AM Thread Starter
Submariner
Submariner's Avatar
2016 JK Wrangler
Well the argument now,
Rebuild it? 258
Replace it it with a bigger engine? 304,360
Recomendations
post #5 of 6 Old 10-15-2021, 10:56 AM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Bent pushrods don't even come close to being a reason to rebuild or replace the entire engine. At this point, even pulling the head may be overkill if it was just something like a mis-tuned engine was simply back-firing.
Figure out what caused it, you may not need to do anything more than replace the pushrods and tune it up.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #6 of 6 Old 10-16-2021, 10:12 AM Thread Starter
Submariner
Submariner's Avatar
2016 JK Wrangler
I am almost thinking that the timing chain jumped a tooth. that is why I am going to pull the head today. This will give me a good look at how the cylinders are. I also need to replace the rear main seal due to it leaking like a sieve. Then I can look at the exhaut manifold for cracks.
and the list goes on and I can clean up some of the mess in the engine compartment.
