axle gear ratios - JeepForum.com
post #1 of 4 Old 01-20-2020, 11:00 AM Thread Starter
extremecustoms
axle gear ratios
Hey, I have a 1991 Jeep Grand Wagoneer that has 4.89 gears in the rear, trying to fine a good gear ratio for the front dana 44 to mess with everything. It has a np229 transfer case with a 2.61 low gear ratio and running 35 inch tires. Any help would be appreciated. Thank you.
extremecustoms is offline
post #2 of 4 Old 01-20-2020, 09:18 PM
kittykitty643
kittykitty643's Avatar
I could be wrong or I don’t understand what it is you’re but the front and rear gears should be of the same ratio unless you can’t find a ring and pinion gear for your front axle in which case you’re going to have to find one that you can match that rear with.. but I could be wrong!
kittykitty643 is offline
post #3 of 4 Old 01-21-2020, 06:42 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Sounds like you're looking for a set of 4.88's for the front......
Unless you don't like the ratio in the rear.
The duty of a patriot is to protect his country from it's government
Thomas Payne
jeepdaddy2000 is offline
post #4 of 4 Old 01-21-2020, 10:51 PM
CSP
As has been said, the front and rear have to match.
That '91 has a Dana 44 rear axle also, if it's the stock axle.
CSP is offline
