84 Jeep Grand Wagoneer V8 Carb Question - JeepForum.com
post #1 of 5 Old 07-11-2016, 07:01 PM Thread Starter
RoscoeRich
1984 FSJ Wagoneer
Hi everyone,
It's been a while since I posted as there's been no time to work on the Jeep. Got it running today, had the carb rebuilt a couple months ago, but something is off. The heat/ choke stove broke off from the manifold. I was told I could run without it. Question is- Do I need to plug those holes to the manifold and openings I might need to plug on the carb. Does anyone have a diagram of how everything comes off the carb?
I put everything back together the way I found it, but the PO may have had it all wrong as it had not run in years. I would appreciate any advice. Thanks in advance!
RoscoeRich is offline
post #2 of 5 Old 07-12-2016, 06:50 PM
OrangeCJ-5
OrangeCJ-5's Avatar
1978 CJ5
The choke tubes inside the manifold are a closed loop and are fine as is. I don't remember how it connects to the carb as far as a vacuum leak is concerned but plugging the port couldn't hurt.
OrangeCJ-5 is offline
post #3 of 5 Old 07-22-2016, 06:35 AM
UZI4U
UZI4U's Avatar
Plug whatever open port you have on the carb and you'll be fine.
MCLMM
UZI4U is offline
post #4 of 5 Old 07-26-2016, 10:05 AM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
mine isnt plugged to my knowledge. As mentioned, its a closed loop.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #5 of 5 Old 07-26-2016, 07:07 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
The vacuum port will be where the pipe connects to the choke housing. You can bend the broken end of the pipe over, use a vacuum cap, or epoxy it shut.
Be sure you readjust your curb idle and idle mixture screws.
Paperwork will ruin any military force.
Chesty Puller
jeepdaddy2000 is offline
carberator , diagram , v8 , wagoneer
