79 j10 brakes... - JeepForum.com
post #1 of 4 Old 10-24-2019, 05:14 PM Thread Starter
vanncann
1979 J-Series Truck
79 j10 brakes...
Does anyone have a step by step how 2 replace the rear brakes on this... Thanks 4 the help!!!
vanncann is offline
post #2 of 4 Old 10-26-2019, 05:18 PM
Dngrs1
1979 CJ7
There are You tube videos on replacing drum brakes. My only suggestion is do one side at a time. That way if you forget how things go together, you can use the other side for reference.
I would rather have a tool I don't need, than need a tool I don't have.
Dngrs1 is offline
post #3 of 4 Old 11-01-2019, 01:38 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
They are pretty normal 10" or 11" drum brakes.
I suggest you verify exactly what size before you get the parts, and if it is all quite old I suggest you at least replace the shoes, the adjusters and the wheel cylinder. The drums often do not need anything. The adjusters come in a service pack with all the springs etc. Figure about $30 per side in parts.
Loosen wheel nits / lug nuts
Jack it up and support carefully with jack stands.
Take off e-brake so wheels can spin
Take off wheels, put under truck. (just in case a stand fails, I am paranoid I will die under a truck)
Loosen off adjusters from behind through the back plate. i use a screwdriver.
Remove drum, you may need to beat with a rubber or hide mallet or use a block of wood and BFH. Do not beat drum with a steel hammer, they can fracture.
Take photo.
Unhook / unfasten the brake shoes
Remove brake cylinder
Clean back plate with brake cleaner
Clean inside of drum with brake cleaner
Install new wheel cylinder
Assemble the shoes, springs and adjuster in same order as you took them off
A small amount of high temp grease on the adjusters and pivot points, if you have it a smear of anti-seize on the end of the axle where the drum fastens to it (you just beat it off, next time you will not need to)
Put on drum
Put on wheel
Adjust adjuster until the shoes start to bite, slacken until they do not touch
Adjust e-brake cable until you can pull them on tight
Bleed wheel cylinder
lower truck
Use e-brake until it adjusts itself tighter
A drum should have a reasonably smooth interior, they can be trued up very cheaply on a lathe if enough metal remains.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #4 of 4 Old 11-08-2019, 09:13 PM
CSP
The factory service manual you can find at oljeep.com has a step by step. Download it in .pdf form for free.
CSP is offline
