73 Wagoneer stock what can you tell me? - Page 12 - JeepForum.com
post #166 of 178 Old 05-06-2014, 05:58 PM Thread Starter
73pumpkin
73pumpkin's Avatar
1973 FSJ Wagoneer
Thanks 1999WJ. I recently had the front and rear seals replaced and gunk should have been flushed out of the pan then. I have looked at the Chilton blow up diagram on the pump. I had the lower end with the oil filter off and the secondary gear dropped out in my hand. I couldn't se a difference from top to bottom, so I stuffed it back in. Is there a difference? Can you rebuild that pump without pulling the timing chain cover, waterpump, etc? I saw the rebuild kits on ebay and there wasn't much to them. I saw the 20-50 oil at the parts store and plan to try it. I did pull the cap on the pressure relief spring, pull it out and put it back. No goodies fell out like the piston valve that is supposed to be up there. Should it have dropped out easily? I should mention that I have 55 lbs on initial start up, but it soon drops down after the engine develops a little heat. In my limited mechanical understanding, this sounds like cylinders expanding and rings loosening. I dumped the barr leak engine restorer in it last night and ran it for five minutes. It is raining like crazy tonight. When the weather improve, I need to slap a little more fiberglass on a gas tank seep while the tank is dry and then I dump some gas in it and see if the pressure improves over the next couple of hundred miles.
73pumpkin is offline
post #167 of 178 Old 05-06-2014, 08:00 PM
super98lsc
The oil pump is really easy to rebuild the gear that fell out is one of the two. The kit is just a gasket and the long gear/shaft driven off the bottom of the distributor and a new pressure valve and spring. The oil is actually getting thinner as it heats up. Some pressure will reduce in all engines as this warming happens. The thing that reduces pressure the most in an older engine is wear in the bearings. The plate on the bottom of the pump can wear and also cause some oil to internally bypass within the pump housing itself same for the case itself surrounding the gears. I flat machined my bottom plate and installed a rebuild kit. My timing cover was in good shape. I think you can use a feeler gauge to check the gear to case clearance for wear? Bulltear makes new ones. The thicker oil should help it remain at a higher pressure when warmed up. Rings won't really come into play for pressure but will cause white smoke and oil consumption, fouled plugs etc if they are excessively worn. Even at 167k miles mine were still in great shape as were the bores. The only wear I found in mine when I tore it down was in the rod bearings and minor wear in the cam bearings the main bearings were all still in great shape. Rule of thumb for an engine is 10 psi of pressure per 1000 rpm. So 10 psi at 1k rpm is fine to live as long as you have [email protected]
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #168 of 178 Old 05-07-2014, 05:29 PM Thread Starter
73pumpkin
73pumpkin's Avatar
1973 FSJ Wagoneer
That is all Excellent information! Can I pull the other gear straight down out of the oil pump housing and then just shove the new one and shaft back up in? This would be an easy improvement well worth a try.
post #169 of 178 Old 05-08-2014, 12:30 AM
super98lsc
Yes it should pull straight down. Keep in mind it's keyed into the distributor like a flat head screw driver so just be gentle putting it all back in to get it lined up.
post #170 of 178 Old 05-08-2014, 07:11 AM Thread Starter
73pumpkin
73pumpkin's Avatar
1973 FSJ Wagoneer
Some of the rebuild kits on ebay have what appear to be sleeves or bushings in them other than the pressure spring and valve piston. Do you know what these could be for?
post #171 of 178 Old 05-22-2014, 11:12 AM
MarkPribanic
Great thread! I have a lot to learn about my 1973 Jeep, lol! Love the color too!
MarkPribanic is offline
post #172 of 178 Old 05-22-2014, 09:05 PM Thread Starter
73pumpkin
73pumpkin's Avatar
1973 FSJ Wagoneer
So... I'm going to look at a 78 wagoner tomorrow with quadratrack. I am mostly looking for an engine to rebuild and a gas tank. Marn has pointed out the offset between a QT and a regular transfer case. Has anyone out there swapped QT axles into a regular d-20 transfer case setup? how did it work out? Did the universals and drive shafts interchange? How about converting the front axles to lockers- was that expensive or difficult? I like the options of heavier axles and the disc brakes of course.
post #173 of 178 Old 05-22-2014, 09:06 PM Thread Starter
73pumpkin
73pumpkin's Avatar
1973 FSJ Wagoneer
thanks Mark. Looks like you have a better start than the rest of us.
post #174 of 178 Old 01-03-2015, 06:00 PM Thread Starter
73pumpkin
73pumpkin's Avatar
1973 FSJ Wagoneer
It has been a long time since I posted anything so I'll catch things up. I have replaced the rotten metal gas tank with a plastic one and shielded it with heavy sheetmetal. I have replaced the radiator and heater cores with new ones. put a new sending unit in the gas tank when I replaced it so the gauge works now. I just bought a 77 4 door Cherokee for the engine and it has front lockout hubs with disc brakes. It also has a manual transmission which I wish my waggy had, but I have already had the tranny rebuilt. Changing over would be a lot of work. Anyway, that is the latest news.
post #175 of 178 Old 02-25-2016, 03:35 PM
robjammin
say what?
77 4-door cherokee?
robjammin is offline
post #176 of 178 Old 02-26-2016, 07:31 PM Thread Starter
73pumpkin
73pumpkin's Avatar
1973 FSJ Wagoneer
Yes 4 door 77 Cherokee. It looks just like a plane jane version of my waggy except it says cherokee on the title and on the side emblems. Currently, the engine from the 77 has been rebuilt with an edelbrock 4 barrel and intake and is awaiting being swapped out into the 73 waggy any day now. the 77 is about 3/4 stripped down to parts.
post #177 of 178 Old 03-06-2016, 10:38 AM Thread Starter
73pumpkin
73pumpkin's Avatar
1973 FSJ Wagoneer
Well the wag is home with the new engine. I have question right off of the bat. I had some issues to begin with, most of which I think that I have cured. I still think I have problem of vapor lock that I did not have before. The engine has an Edelbrock Performer intake on it with a 1406 four barrel. The fuel line now has a rubber line that runs from the filter around to the passenger side of the new carborator. After the engine warms a bit, it will not start. If I pull the hose off, either up stream or downstream of the filter, with the engine off of course, gas and vapor blasts out. then the engine will start. I have read some of the posts on vapor locking and plan to try some of those solutions. my question is; my engine swap and intake/ carb conversion seem to be a common event, has anyone else out there experienced a similar problem? If so, what were their solutions?
post #178 of 178 Old 06-13-2021, 03:52 PM Thread Starter
73pumpkin
73pumpkin's Avatar
1973 FSJ Wagoneer
I have not posted on my thread for a very, very, long time. The pumpkin is still mine and still running. I have not done much to it in a while. I am building a garage to put more modern axles from a 78 under it. If any of the old gang still reads this forum, feel free to stop in and say"Hi." I'll probably monitor it regularly for a while now.
66 Wagoneer or 89 Grand Wagoneer jlsfitness Full Size Jeep Forum 12 01-24-2012 08:40 AM
My 88 Wagoneer hemilady Full Size Jeep Forum 9 11-14-2009 06:34 AM
Stock Tie rod lenght of 89 grand wagoneer?? djeep1994 Full Size Jeep Forum 7 09-13-2009 08:09 PM
wagoneer/grand wagoneer differences? JeepnBlake Full Size Jeep Forum 1 08-26-2008 10:33 PM
87 Grand Wagoneer Stock Specs extankerguy Full Size Jeep Forum 5 02-03-2005 03:56 PM
