Rough Idle - JeepForum.com
post #1 of 13 Old 06-20-2016, 09:18 PM Thread Starter
Wheels447
1988 MJ Comanche
Rough Idle
hi my 1988 jeep comanche has a rough idle from lets say 900 normal then drops to 150 or so relay bad then it go's back to normal but some times it dose do it then others its normal
i have replaced the IAC valve and TPS i dont know what else it could be
Wheels447 is offline
post #2 of 13 Old 06-21-2016, 06:37 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Before wasting any more time or spending any money, make sure your intake manifold bolts haven't loosened up and then go to www.cruiser54.com and do Tips 1 through 5 thoroughly.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #3 of 13 Old 06-21-2016, 04:32 PM Thread Starter
Wheels447
1988 MJ Comanche
Ok will do think you
post #4 of 13 Old 06-23-2016, 06:50 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Tip 8 shows you how to adjust the tPS properly.
post #5 of 13 Old 08-09-2016, 11:17 AM Thread Starter
Wheels447
1988 MJ Comanche
Ok so it has not gotten any better someone told me that it could be a compression problem
post #6 of 13 Old 08-10-2016, 02:43 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Could be many things.
Do a compression test and post up the results.
Could be worn out tune up parts, bad oxygen sensor etc etc.
post #7 of 13 Old 03-29-2017, 11:34 AM Thread Starter
Wheels447
1988 MJ Comanche
Compression is good but now I have a new problem sometimes when I drive in second gear and up when I get to in between 2100rpm and 2600rpm it back fires a lot but once it gets out of that it drives fine and it really random when it dose it I replaced every thing electrical except the computer and it still dose it
post #8 of 13 Old 03-29-2017, 03:06 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Ever been here..www.cruiser54.com... and done tips 1 through 5?
post #9 of 13 Old 03-29-2017, 10:00 PM
Nick05
1994 XJ Cherokee
You said you replaced the tps, did you adjust it properly? Mine does the same thing when it's running but since I am the only one who drives it I don't care. Check your grounds and look into c101(?) Removal would be where I would check after verifying tps is set right and tune up Parts are good.
Nick05 is offline
post #10 of 13 Old 03-30-2017, 12:54 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
100% correct Nick.
post #11 of 13 Old 03-31-2017, 06:23 AM Thread Starter
Wheels447
1988 MJ Comanche
I don't know I probably did not adjust it right
post #12 of 13 Old 03-31-2017, 07:04 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
http://cruiser54.com/?p=54
post #13 of 13 Old 04-01-2017, 11:01 PM
Nick05
1994 XJ Cherokee
Originally Posted by cruiser54 View Post
Follow his advise. It has helped many jeepers
Nick05 is offline
