JeepForum.com (https://www.jeepforum.com/forum/)
-   MJ Comanche Technical Forum (https://www.jeepforum.com/forum/f53/)
-   -   Comanche Leaf and Shackle (https://www.jeepforum.com/forum/f53/comanche-leaf-shackle-2973769/)
cyclejeep 01-25-2015 01:50 PM
1 Attachment(s)
I've got a 1989 comanche that I am attempting to install a Rusty's Offroad Products 4.5" lift. Front end is complete which was a total piece of cake thanks to all of the anti-seize used at the factory :drool: The rear end is another story. The spring pack has considerably more arch and as such requires that the shackles be pulled so far forward as to touch the frame (not good). Anyone run into this problem? Solutions?
Motorcharge 01-25-2015 05:59 PM
You don't have the leaf packs on backwards do you? And you did order the Comanche and not Cherokee leaf packs right?
LAF1269 01-25-2015 08:44 PM
If I had to guess, I would say that you might have XJ leaf packs on there. What's the part number on the leaf spring?
cyclejeep 01-26-2015 07:09 AM
1 Attachment(s)
I'm confident that the spring is in the correct direction. The spring part # is ROPCOM35-0. When measured along the leaf, they are the same dimensions as the factory springs. However, they are significantly more curved.
Motorcharge 01-26-2015 07:14 AM
Then they must be backwards. They shouldn't be centered on the axle. There's a short and a long side.
cyclejeep 01-26-2015 07:14 AM
1 Attachment(s)
Picture from the rear showing springs.
cyclejeep 01-26-2015 07:20 AM
Thanks for the feedback Motorcharge. There is a variation in length between eyelet and centering pin (26" and 31"). Even before mounting the axle, the length demands that the shackle be forward which tells me that the eyelet to eyelet length may be too short...or am I missing something else. Must the axle be mounted before attaching the rear leaf to the shackle?
LAF1269 01-26-2015 07:58 AM
I checked Rusty's site and couldn't find a match for that part number. Google came up with nothing also. There was a photo of an XJ 4.5 kit that had a legible part number on the spring that read ROP-XJ45-0. If that part number code applies to all of their kits then it looks like you don't have a 4.5 inch spring. I'd call Rusty's and have them sort it out for you.
Motorcharge 01-26-2015 04:53 PM
Yeah I got nothing on the part number either though I do see it in the picture. Just looked at mine and the short side is forward. MJ leafs are significantly longer than XJ leafs are and one side is obviously longer on them. As for the arch in them, they should have a lot more than factory with a spring under setup. Having no weight on it might make some difference but not that much. Even when I have mine on a lift at work the shackle isn't touching the frame.
They've got to be XJ leaf packs. If they were on backwards the axle would be pushed noticeably too far back. If they're XJ leafs they'd be too short and pull the shackle forward like they're doing.
cyclejeep 01-26-2015 05:24 PM
It appears that XJ spring #s are ROP-XJ45-0. I missed Rustys on the phone today. I'll try back tomorrow and report! Thanks guys.
jkufrancesca 07-12-2019 03:23 AM
Did you ever figure it out?
CJ7-Tim 07-12-2019 05:02 AM
It is very common for XJ and MJ leaf springs to "seem" to be too short. Often I have had to install the front bushing bolt and then lower the Jeep to put weight on the leaf spring to install the rear bolt. You do have to be careful the Jeep doesn't fall off the jack or jackstands, and that you don't get your fingers or hands caught between the springs and other hard stuff.
Obviously the larger bushing is the front bushing, so you really can't put them in backwards.
jkufrancesca 07-12-2019 07:17 AM
Yeah I’m just curious I bought the same ones yesterday part number ropcom35-0 and was told they were removed from a Comanche but the shackle on them adds another 4” of lift I just bought the springs for a solid four so curious if the stock would be problematic. But I’ll try and get to them today with some weight
The time now is 04:00 PM.
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
