Chasing gremlins (parasitic draw) - JeepForum.com
post #1 of 2 Old 06-08-2021, 11:35 PM Thread Starter
Mutt1992
I have a power draw in my 89 Comanche, kills my battery if I leave it over night. I tracked the culprit down to my brake. The volt meter show me that when I engage the brake (key off), that the amps jump from .01 on a 20 amp gauge to 8 something. I'm not sure where to start looking to fix it.
Edit: I guess what I need to know is where do all the wires that go from my brake pedal end up? I'm trying to narrow it down before I have to take my whole dash off and just keep chasing gremlins. I'm not even sure it's the brake, but it did make the volt meter jump.
Mutt1992 is offline
post #2 of 2 Old 06-09-2021, 11:58 AM
87MJTim
87MJTim's Avatar
1987 MJ Comanche
If you don't already have this, I would start with the wiring diagrams for the MJ. https://comancheclub.com/topic/12083-electrical-manual/
It is for the 88, but 89 should be identical.
One place to start your search is a bad tail light socket or a bad ground in the tail end. For the ground, remove the driver's side tail light and check the ground connection located on the sheet metal.
Be sure to check out Cruiser54 Renix tips at www.cruiser54.com
Lots of videos on youtube for chasing parasitic draws. Watch several of those to determine the best approach to tackle this.
Tim
87 Comanche, 4.0, AX15 (formerly BA10/5), D44
84 CJ7, 4.0 (93 XJ) AX15 (Formerly T5)
87MJTim is offline
