Brake issue! - JeepForum.com
post #1 of 6 Old 07-15-2019, 12:37 PM Thread Starter
bigjon99
bigjon99's Avatar
Brake issue!
I have a 1988 MJ. I have an issue that I have been working on for about a month with no positive result. My brake pedal is stiff when I have the car off, but when I turn it on the pedal goes right to the floor and I get no pressure. I have replaced- Brake booster Master cylinder Both front calipers and pads Brake lines connecting cylinder to proportioning valve.
PLEASE HELP I want to be able to drive this.
bigjon99 is offline
post #2 of 6 Old 07-15-2019, 03:29 PM
87MJTim
87MJTim's Avatar
1987 MJ Comanche
The MJs came with “distribution valves “ that have a bypass line when there is a brake failure. The bleeding steps are different than a proportioning valve. Have you followed the factory steps to bleed the brakes?
Tim
87 Comanche, 4.0, AX15 (formerly BA10/5), D44
84 CJ7, 4.0 (93 XJ) AX15 (Formerly T5)
87MJTim is offline
post #3 of 6 Old 07-15-2019, 04:00 PM Thread Starter
bigjon99
bigjon99's Avatar
Yes I followed the factory steps to bleed the brakes. Is the distribution valve something I can check or replace?
bigjon99 is offline
post #4 of 6 Old 07-15-2019, 04:06 PM
87MJTim
87MJTim's Avatar
1987 MJ Comanche
You could swap out to a proportioning valve.
Here are some links to the MJ brake and fixes and work arounds:
https://comancheclub.com/topic/53274...ete-procedure/
https://comancheclub.com/topic/47993...ioning-valves/
https://comancheclub.com/topic/51268...delete-bypass/
Tim
87MJTim is offline
post #5 of 6 Old 07-15-2019, 04:32 PM Thread Starter
bigjon99
bigjon99's Avatar
Originally Posted by 87mjtim View Post
you could swap out to a proportioning valve.
Here are some links to the mj brake and fixes and work arounds:
http://comancheclub.com/topic/53274-...ete-procedure/
http://comancheclub.com/topic/47993-...ioning-valves/
http://comancheclub.com/topic/51268-...delete-bypass/
thank you!
bigjon99 is offline
post #6 of 6 Old 10-27-2019, 04:38 PM
Sam-daily
Sam-daily's Avatar
I second the prop vale swap... even if its only to help you isolate the issue to one circut vs the other...
Sam-daily is offline
